Thread: Wiring sidelights to cigarette lighter?
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default Wiring sidelights to cigarette lighter?
    As titled can this be done? Am sure I read something before, Just I am wanting to get the led type bulbs for the sidelights...how hard do you think it would be to wire up?thanks
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Easy, couple of wires and a switch fed to the front of the car...
    Edit: i was looking at the blanking plates for the heated seat switches today, i reckon switches would fit there nicely...
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Or if you want them on all the time like DRL's just dont bother with the switch. I would put an in-line fuse on the +ve feed just to be on the safe side. So I take it you would get 2 bulb holders from another car and leave your original sidelights taped up somewhere Good idea
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    yep use bulb holders from another car, was thinking of the cigarette lighter circuit as it comes on when unlocking the car and when sidelights are switched on...2nd set of mtec's gone now
    23 Post(s)
    Mileage : 110k
    Quote Originally Posted by Morephun View Post
    yep use bulb holders from another car, was thinking of the cigarette lighter as it comes on when unlocking the car and when sidelights are switched on
    That sounds even better... Do it
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    will do, where/which is the best grommet to push through cabin to engine bay
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    i would take it from the fuse box under the bonnet..theirs bound to be a switch live in their.. that comes live when cars unlocked?
    great idea though
    ayrshire scotland
    Glovebox out and the big one behind there is the easiest way
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Switch live will definately be in the Under-bonnet Engine Fuse Box...
    Just look in the owners manual for a suitable take off point.
    This will also save the hassle of messing with removing the scuttle panel, to get at the grommet that you would need to use to get from the engine bay, to the insides, behind the glovebox.
    relay 5 is the ignition live - "Terminal 15"
    you could use fuse 14, which is the "head lamp wash system" fuse.
    to do it properly, you could take a feed from the BCM, but that would involve the dreaded grommet etc.
  1. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
  2. Cigarette Lighter
    By SB3871 in forum Bodywork & Interior
    Last Post: 30th July 2009, 13:55
  3. Cigarette Lighter
    By BJRM7241 in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2009, 16:28
  4. cigarette lighter
    By PYNE999 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 11:28
