Results 1 to 10 of 14
Thread: Bulb failure warning for factory Xenons?
    Melbourne, Australia
    Question Bulb failure warning for factory Xenons?
    Hi everyone,
    Once again I'm pondering various aspects of fitting Xenons to my car...
    Here's a question for anyone with factory fitted xenon or bi-xenon/AFL headlamps: Do they have the bulb failure warning system for the xenon bulb or just the halogen bulbs?
    Thanks.
    Ive got xenons on the Elite and am pretty sure they do have bulb failure warning on them my previous veccy "B" had xenons and that deffo had bulb warning on it as one bulb blew on that !!!!! HTH
    Feb 2006
    Guttedsville
    Bulb warning? doesn't it go all dark and you hit a Kangaroo / Badger / Deer / pensioner?
    Quote Originally Posted by Andrew's SRi
    Of course it's very easy for a human to detect that bulbs aren't producing any light
    What I'm wondering is: Do the car electronics detect failure of a xenon bulb, and if so, how do they do it?
    Indeed, how do xenon bulbs fail? (glass breaking, gas leakage, ...?)
    Nicking Ya Dinner.
    How much is a Xenon bulb? in the book it recommends you get the dealer to change it for you, is it a hard/dangerous task?
    Steve,
    Yes the car electrics will detect the failure of the xenons..If it can't get then to light it'll flag a faultcode..
    Quote Originally Posted by VauxVeteran
    Xenon bulbs ( VX) are £137 retail, £116.50 trade, £79.52 T/Club..Pt No. 9117208
    I guess they want to do it, as the costs involved are horriffic and if you're a butter fingers..
    Quote Originally Posted by Gsi3.2
    So Gsi3.2, can it detect the failure of an "off" bulb, or can it only detect failure when it tries to turn the bulb "on"?
    The bulb failure seems to work against the lighting system 'knowing' the electrical load being applied to the curciut..So if the load isn't what it expects..like a blown bulb, or a bulb that's not fitted or even a trailer kit then it will flag a fault..
    I understand this is the reason that the towbar kits have to be TECH2'd to the car, to advise the lighting 'computer' that there will be a differnt load being applied to what the base standard is..
    Feb 2006
    Guttedsville
    Mine flagged up a failed headlight bulb ( non Xenon ) on the brightest, sunniest day of the year. It said simply " check left low beam bulb " Sure enough, swithced it on and it wasn't working.
  1. Bulb Failure warning
    By Casey in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2012, 16:31
  2. Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 19:20
  3. bulb failure warning light on dash
    By bigbill94 in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 19:35
  4. bulb failure warning
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2010, 11:03
https:www.vectra-c.comforumshowthread.php9994-Bulb-failure-warning-for-factory-Xenons
