Thread: traction control and abs lights on....?
    Apr 2009
    leven, fife
    Default traction control and abs lights on....?
    hey there got a problem with my vectra c the traction control light and abs light are both on constantly and wont do off w'eve had it on a dianostic tool and its came up with sensor fail in offside front hub obviously the full hub needs changed with the sensor but here's my problem....... i have a practical driving test early next week and i'm wanting to take it in the vectra and they will send me straight home if the abs/traction cnontrol lights are on constantly and that i dont want
    so my question is can i disable the lights or bypass them some how?
    also i dont have spare spondoolies to change the full hub right now so thats not an option.
    thanks.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    take the fuse out mate
    Apr 2009
    leven, fife
    what fuse?
    are they clearly marked
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    have a look in the manual mate or get tech2 on it and turn them off
    Nottinghamshire
    I got a very similar (might even be the same) fault description a week ago. I was told Iwould need a new hub as the wheel speed sensor has failed and is built into the hub. The actual error I got was something like 'nearside front wheel speed sensor voltage high'.
    On a hunch, I took the appropriate sensor wiring connector apart (at the back of thr wheelarch) and it had water in it. I dried this out, sprayed in a bit of electrical contact cleaner, then dried that out, put it back together and the fault light went out.
    Might be worth a try - especially if the fault code you got was the same or similar to the one I got and because it's practically free.
    PS - not sure if you can even disable the ABS/TC on a Vectra C due to Canbus, but why disable a safety system in any case? If you really do need a wheel hub, you'll have to save up and get one as soon as you can. Note that the ABS and TC won't work while the warning lights are on.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    he needs the off he got a driving test next week hence the reason pull the fuse or do somet with it
    Apr 2009
    leven, fife
    just took out fuses 16 , 29 , 32 and its still on....
    Nottinghamshire
    Sorry, didn't see the bit about the urgent requirement to get the lights off. Checking the wiring connector will take less that an hour - jack up, wheel off, unclip connector, clean and dry, put back together, check lights go out (which all fuses back in first!), then wheel back on and lower car.
    The manual lists all the fuses in the fuse section - I think there's about 5 or so in 2 of the 3 fuseboxes. Download the manual from the Vauxhall website if you don't have a copy with the car.
    This may still not switch it off though. The warning lights are probably controlled by whatever controls the instrument panel (the CIM?) which is being told to put them on by the ABS controller and they will probably stay on if the CIM doesn't get any signal at all from the ABS controller as that would class as a fault too.
    Apr 2009
    leven, fife
    sorted well for the time being lol
    Nottinghamshire
    Quote Originally Posted by jungle View Post
    What did you do?
  1. power steering and traction control lights on
    By Rob12 in forum Y & Z30DT Specific
    Last Post: 22nd March 2013, 18:42
  2. ABS & Traction control lights on?
    By keithsimmo in forum Suspension, Wheels & Brakes
    Last Post: 3rd January 2013, 20:17
  3. A.b.s/traction control warning lights
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2009, 00:08
  4. a.b.s. traction control lights
    By simplesi in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 11:40
  5. Abs & Traction control lights on
    By iceeee in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2009, 16:17
vectra c abs and traction control lights on
abs and traction control light on vauxhall vectra
vectra c abs light
vectra c abs light on
vauxhall vectra abs and traction control light on
abs tc light on meriva
vectra 2.8 traction light
https:www.vectra-c.comforumshowthread.php99918-traction-control-and-abs-lights-on
Abs traction vectra
vectra vxr traction controlvauxhall insignia abs warning and traction lightvectra c traction control and abs light onVauxhall vectra c abs problemshow to reset abs warning on opel vauxhal vectra cabs light vectra czafira b tractionabs light and traction control light in my vauxhall insignia 2011zafira abs and traction control lights onmeriva b abs tc lightopel vectra abs fusemy abs and traction control light is on vectra cvauxhall vectra c abs and traction lighttraction and abs light vauxhall vectravauxhall signum abs lightvectra c abs and traction control light quick fix
