Thread: op-com limits
    SAUCHIE
    Default op-com limits
    Hi all.
    I put my op-com on my 58 cdti150 just to look at a few things as its drinking fuel,last check it was 32.8mpg and i checked the special functions and the EDC 16 correction cylinder quantity deviation and this was the results. 1st test
    cylinder 1 0.09
    cylinder 2 0.06
    cylinder 3 -0.31
    cylinder 4 0.14
    2nd test
    cylinder 1 0.22
    cylinder 2 0.20
    cylinder 3 -0.73
    cylinder 4 0.30
    I think there may be a problem with number 3 cylinder or injector and was wondering if anyone can shed any light on these limits.
    many thanks
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    think the tolerance for these is -0.65 to 0.65 if I'm right anything outside this range of correction points to a fubered injector somewhere
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    SAUCHIE
    Thanks I am just wondering why number 3 injector is so much different from1 2 and 4
    Nottinghamshire
    I don't have a CDTI so I'm not that familiar with them, but isn't there a fix for a problem with the 3rd injector on some CDTi engines - to do with the electrical wiring to the injector getting too hot or something. There's a kit with some replacement wiring and connectors. Might be worth a search...
    SAUCHIE
    My car is still under warranty but the ***** at vauxhall says that 32 -38 mpg is really good for a 150cdti. PISH I said !! The fitters there don't seem to want to touch anything unless it shows up on tech2. They are fitters and not mechanics as it seems they need to be lead all the way !!! I was a trained mechanic a few years ago and some of these boys really havn't a clue how to check cars unless they have a computer which is sad really.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    in winter stop/start short journeys mine will fall to around 35-36, normal driving, but rises vastly in warmer months on the same journeys, longer journeys give much better mpg.
    SAUCHIE
    You have a faulty thermostat it should not fall to anywhere near that.
    Nottinghamshire
    Quote Originally Posted by scotstrucker View Post
    I think maybe there's a mix-up here between MPG and temperature in degrees C ???
    Anyway, perhaps ask your dealer about the 3rd injector repair kit and whether your car might need it, and whether it might be related to the issue you are seeing.
  1. Speed and limits
    By Grumpy1954 in forum General Chat
    Last Post: 12th May 2010, 20:42
  2. M25 speed limits
    By tempo in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2008, 03:41
  3. Site for speed limits.
    By rushy in forum General Chat
    Last Post: 15th January 2008, 19:57
  4. Limits of remaps
    By nutron in forum Diesel Engine related
    Last Post: 13th December 2007, 18:07
injector wiring test opcom
