Thread: First MOT booked in for tomorrow. Few questions
    Vale of Glamorgan
    Default First MOT booked in for tomorrow. Few questions
    After a year of loyal service, the Vectra is booked in for its first ever MOT tomorrow. She's a 1.9 CDTI (150) with 66k on the clock and no noticably major problems. Hopefully she will fly through it but I have a couple of queries if anyone can help me out with them.
    Firstly, a rear break light has been replaced several times with standard off the shelf bulbs and they all seem to be considerably dimmer than the factory fitted bulb. Is there a special bulb I should be going for and will they fail me on MOT for a dim bulb? I suppose I could ask the garage to change it before MOT.
    Secondly, I have a couple of hairline scratches in my windscreen. You can opnly see them in certain lights but they can occassionaly draw your eye. I knowa crack overa a certain length is failable but are hairline scratches and if they are is there anything I can polish them out with myself?
    Fingers crossed she gets through it as she's been nothing but a pleasure to drive in the last year.
    Thanks for any input, its appreciated.
    Regular Member scottyd's Avatar
    paisley
    itll be your imagination unless you are buying the wong bulbs, they prob wont notice the windscreen so dont worry
    Vale of Glamorgan
    Nope, its definately dimmer. Several people have commented which is why ive changed bulbs several times.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    buy a bulb from vx mate and check that all the electrical pins are clean
    Ashington, Northumberland
    The stop lamps could well be failed if they are deemed by the tester to be 'not in good working order' as defined by section 1.3.2b of the testers manual, which states;
    (Any stop lamp)
    that is incomplete, not in good working order or in clean condition, ie so damaged or deteriorated that its function is impaired
    As for the windscreen, from what you describe, you should get an advisory at the most.
    Good luck
    Vale of Glamorgan
    Cheers guys, will get the garage to change bulb, then its upto them to get it right!
    Vale of Glamorgan
    Well she made it through without any problems or advisories. Result! thanks for the advice guys.
  1. Insignia VXR Test drive booked for tomorrow so I have a few questions.
    By Big Sig in forum Insignia Chat (READ ONLY)
    Last Post: 24th February 2012, 23:59
  2. it's booked in
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2010, 19:30
  3. Look where ive been booked!!!
    By mc_orion in forum The 'Off Topic' room
    Last Post: 30th July 2009, 20:27
  4. Its booked in....
    By signum_1.9 in forum Suspension, Wheels & Brakes
    Last Post: 17th February 2009, 19:38
  5. car booked in vx for tomorrow
    By vectra 2.0 t in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2006, 21:32
