Results 1 to 10 of 11
Thread: Boot light
    Jan 2010
    uk
    Default Boot light
    I have a 56 reg 1.8 Vectra SRi and have just noticed there is no light in the boot. Has anyone got around this problem with a simple solution?
    Last edited by tabster; 15th January 2010 at 12:03. Reason: In the wrong forum (rookie mistake)
    Hanging Heaton / Batley
    16 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Is the lense there on the left hand side facing in towards the seats?
    Jan 2010
    uk
    No, there doesn't appear to be any lamp housing at all, unless I'm being simple
    16 Post(s)
    Mileage : 110k
    it should be on the left, but on the boot "wall" your looking in from, just inside the N/S rear light if that makes sense (you'll see it if get your head in to change bulbs on rear lights)...
    My mates life model has one so i guess they all do...
    If yours is there, just not working pop off the lense and see if the wires are connected - chances are there not...
    If their there connect them, make sure its right way round as one way it keeps on permanantly, other way turns off when boot closes... to check this shut boot and look through the rear arm rest panel... its probably been disconnected if stayed on before as pre owners prob thought it was a fault...
    Failing that, a 3ft - 36 inch neon tube (or under car kit front or rear tube) fits perfectly screwed to the parcel shelf hinge brackets. i plan to do this soon as the standard lights rubbish anyway obviously just connect to your existing wires...
    Last edited by Leemarksmith; 15th January 2010 at 12:28. Reason: Because i spell like a 10 year old... :-)
    Jan 2010
    uk
    Thanks mate, I'll check it out.
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    alot of car dealers disconnect them for when they are sat on the forecourt with the boot open aswell.
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    I thought this when I first got my vec, turns out the bulb was out!
    Regular Member i5aces's Avatar
    andover
    i got a 12v strip light and screwed it into the back of the seat with small screws, (cant see the holes when removed) wired it into the oem wiring so only comes on when the boot is open, works a treat and lights up the boot really well
    Quote Originally Posted by keith1983 View Post
    I don't know why they do this as after approx 5 mins it turns itself off anyway.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to proper section
    Irmscher Insignia CDTI 130
  1. boot light
    By chrosty in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2011, 09:11
  2. New boot light
    By bobssignum in forum Styling
    Last Post: 19th May 2011, 10:56
  3. Boot light, should I have one ?
    By sharpo in forum Bodywork & Interior
    Last Post: 27th February 2010, 13:49
  4. boot light
    By samuel hosick in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 13:07
boot light faulty on vectra c
