Thread: Low Beam Error
    Mar 2007
    Rotherham
    Default Low Beam Error
    Morning everyone,
    I got in my 56 Plate vectra SRI this morning and upon turning the lights on only one headlamp came on.
    I turned the lights off and back on and none of the Low Beams worked and I received a low beam warning on the screen and light came on the instrument panel.
    Side lights still work
    Full beams still work
    Anyoone know where I should start looking ?
    I cant imagine it being a fuse as Full Beam and side lights still work.
    Any help or advice appreciated.
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Have you tried changing the bulbs...
    Mar 2007
    Rotherham
    Quote Originally Posted by leemarksmith View Post
    Not yet, thought it would be unusual for both to go at the same time, but yes thats the obvious first thing to try.
    23 Post(s)
    Mileage : 110k
    Unusual but likely answer... if no bulbs to change to now, and want to check there's no other issue... put the lights on, then take the bulbs out of the headlights but still connected to the car and give them a shake. if the filament catches it'll reconnect and light up (most of the time anyway)
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    In an emergency, swap the high beam bulbs to the low beam positions. OK, you won't have high beam, but you will have low beam..... which is more important most of the time?
    11 Post(s)
    Quote Originally Posted by deano_uk View Post
    Separate fuses for the main, dipped and side lights, IIRC.
    Quote Originally Posted by Ste View Post
    Not possible. The OP's car is a 56 reg. The main/high beams use H1, the dipped beams use H7.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I didn't notice that. On prefacelift they are the same bulb type. my bad.
    Mar 2007
    Rotherham
    it was the bulbs that had blown, or will there be some underlying fault that caused them to blow....time will tell
    Nottinghamshire
    Also bear in mind that the bulb failure system appears to be very sensitive. It will often detect a bulb that is working OK at the time but will probably - though not always - fail soon.
  1. Hid beam
    By dannyp in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 13:16
  2. Better Dip Beam
    By insignia28 in forum Styling
    Last Post: 6th July 2011, 19:03
  3. Full Beam/Dipped beam
    By ontoplums in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2011, 18:06
  4. Low beam
    Last Post: 30th December 2008, 19:31
low beam vectra c
low beam vectra
vauxhall astra low beam warning
low beam vectra c greska
low beam warning light twintopopel vectra c dipped beam faultopel vectra low beamvectra low beamvectra number plate lit up on low beam messageopel vectra c low beamlow beam error on zafira bvectra low beam warninglow beam opel vectra cvectra c low beamlow beam vauxhall astravectra c which light is low beam2005 astra 1.9 cdti low beam warninglow beam message in car vauxhall astra cdtilow beam lights vectra c problemhttps:www.vectra-c.comforumshowthread.php99891-Low-Beam-Errorloe beam fault code on astrainsignia dipped beam bulb warning wont golow beam warning vauxhall zafiravectra sri low beamvectra c low beam warning
