Results 1 to 10 of 11
Thread: anyone know where boost sensor is??
    Regular Member signum03's Avatar
    worthing
    Default anyone know where boost sensor is??
    evening all, would like to clean my boost sensor on my 3.0 v6 cdti signum(03) does anyone know where it is?if possible a picture! thanks all
    Full Member Big Sig's Avatar
    yes but I cannot do pics as I don't have the car anymore.
    Remove the black plastic engine cover, its at the back right hand side - not too far from the turbo. You will see a black "cable tray" and its partly under that.
    Its also hot the word BOOST written on it iirc, mine was grey in colour, iirc its held in with 1 or 2 bolts. Careful when you take it out/replace it as its got a rubber o ring that can get damaged, a small amount of grease on this will help when you put it back.
    HTH
    worthing
    thanks for that bud, i read a post from a few days ago from people doing this with good results so wanted to try!
    Mine wasn't that dirty but it needed doing. Just be careful that you don't push the crap into the sensor
    worthing
    just so i know are they quite fragile or robust etc? dont want to damage it and i assume carb cleaner is the best bet? also wouldnt mind cleaning the egr valve but again i am unsure on its location, there isnt much in the way of how 2s on here for my engine
    worthing
    removed engine cover and i swear i have looked everywhere for the boost sensor and cannot find it! help!
    worthing
    bump!
    worthing
    bump! can anyone help?!
    As in my post no.2. Its right at the back near the black cable trunking - same end as the turbo.
    ABout 50mm square, gray with 2 bolts on it. has the word boost written on it. Its right at the back, near the bulk head.
    Post a pic up and I'll put an arrow to the approx area.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Under the red dot
  1. boost sensor on the 120
    By SarahP in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 22:25
  2. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
