Results 1 to 10 of 13
Thread: different cruise control problem
    Aug 2007
    woking
    Default different cruise control problem
    I have an 07reg 1.9cdti 120hp exclusive estate.
    After reconnecting the battery after charging it the cruise control has gone all jerky. Before the battery went flat you set the cruise control and it kept the speed very smoothly but since I charged and reconnected the battery you set the cruise control and it works but it feels like you are pumping the accelerator pedal the speed only varies by a mph or so but it makes the journey very uncomfortable. Any ideas????
    11 Post(s)
    Try disconnecting and reconnecting the battery again.
    Aug 2007
    woking
    Done that . Still the same
    Jan 2010
    UK
    Some ECUs reset the map to the default after being disconnected from the battery, does this happen with the vectra ECUs?
    Jun 2013
    ljubljana
    Vehicle : vectra c
    Trim : elegance
    Engine : 1.9 cdti
    hi folks
    I have same problem with CC. When set feels like you are pumping acelerator.
    What have you done to solve this problem?
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    I changed the throttle body for a new one to sort mine out
    Just used to judder around the 2000 rpm mark which was 70mph ish in 6th...
    Used to drive me nuts...
    Regular Member Ed307's Avatar
    Apr 2015
    Dublin, Ireland
    Vehicle : Vauxhall Vectra
    Trim : Exclusiv
    Engine : Diesel
    Quote Originally Posted by Slammedorion View Post
    Hi, brand new or a reconditioned one? Having exactly the same problem!
    Mar 2012
    cheshire
    11 Post(s)
    Quote Originally Posted by Ed307 View Post
    Brand new from ECP
    Any second hand one will probably have the same fault
    Apr 2015
    Dublin, Ireland
    Trim : Exclusiv
    Engine : Diesel
    Brand new from ECP
    Thanks for that - I see 3 listed on ECP's site - does it matter which one you order, all listed as 'OE quality'
    Mar 2012
    cheshire
    11 Post(s)
    I just ordered off my registration
  1. cruise control problem
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2012, 22:07
  2. Cruise Control Problem
    By gsi.vxr in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 13:16
  3. cruise control problem
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2009, 21:37
  4. cruise control problem
    By Herman in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2008, 19:10
  5. Cruise Control problem, HELP pls
    By Ridah in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2008, 11:06
