Thread: Washing car with hot water.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Washing car with hot water.
    At work, I've managed to plumb in a garden hose tap to the hot water system. The temperature of the water is a constant 65 deg C.
    Can using a hose with such hot water on the car do any damage to the paintwork or anything else? Obviously not going to hose frozen windows off , it's really for those days when it's a bit warmer and seemed a good way of hosing off road grime.
    Any thoughts?
    Cambridgeshire
    If you are using it for spraying the car down then you shouldn't have a problem mate.
    It won't damage the paint, in the sun dark cars paint can reach temperatures of nearly 75 deg C so i'm sure some hot water will be fine mate
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by parsco View Post
    Thanks mate. The hot water is really only for loosening up the accumulated grime on the lowers and the alloys. Thanks for the confidence booster.
    Regular Member bigbnlr's Avatar
    Belfast
    I don't rinse with hot water but I do use hot water in the buckets.
    Wales, UK
    Yep, well I know its not quite as hot, but use the hot tap to fill my buckets, never really had a problem.
    Nice idea by the way !
    Jan 2010
    Yorkshire
    You shouldnt have any problems, I own a mobile car valeting company, we use diesel pressure washers which heat there own water to slightly higher temperatures than that.
    Regular Member david.aka.judas's Avatar
    Suffolk
    spec from a heated pressure washer:
    Technical Data:
    Discharge capacity: 300-660 litres per hour
    Pressure: 30-100 Bar
    Temperature: 30-90 DegC
    Voltage: 230v 50Hz
    Connected Load: 3,0Kw
    should be fine.
  1. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  2. Washing
    By Redviper in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2009, 12:09
  3. washing car with washing liquid
    By gallag in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2008, 16:34
  4. washing your car
    By steve.s in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2007, 15:57
