Thread: no blowers/heaters 3.2 gsi
    Regular Member vegasbaby's Avatar
    BARNSTAPLE
    Default no blowers/heaters 3.2 gsi
    Evening/morning chaps, the climate control in me vec, has given up the ghost. Over the past few days it would work after awhile, but now has stopped altogether , apart from a quiet whirring noise. Any ideas would be most welcome, and the more info the better, as I am a mechanical/electrical "retard"! Thanks.
    Regular Member PauloMcGuinee's Avatar
    Jul 2009
    Milton Keynes
    I am in the same "cold" boat - did you get anywhere with this?
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    I would guess the blower motor has gone - as I say, a guess, but seems logical and I believe it is located behind the glove box.
    I think the resistors are also a common fault but tend to hear that it means you lose 'speeds' rather than the thing all together?
    Sorry for the rubbish answer but may be a start! Someone else on here i'm sure would know so here's a free bump
    Jul 2009
    Milton Keynes
    I have the dual zone climate control module, does this make any difference or shall I still take a look behind the glove box and hope that something really obvious jumps out at me?
    Mar 2007
    North East
    Climate control has a different type of controller on the fan. There are a few threads about faults on them, they ain't cheap to replace....
    Jul 2009
    Milton Keynes
    Well as if by magic the heater was working again this morning... hopefully it was a blip and I can forget about it. Or its on its way out and just teasing me. I am worried I will have to sell this car as I have already had to sort out an angle sensor costing £300 in November and now this. Also I have just been quoted best part of £600 for a Cambelt change/service and MOT
    Jul 2009
    Planet Earth
    Trim : GSi & Design
    Year : 02/07
    Quote Originally Posted by PauloMcGuinee View Post
    Ouch on the service and cambelt change! I do the servicing on mine myself, once you've done it a few times, it's really not that bad and saves a lot of money - just nuts and bolts really. (yet to the spark plugs though - will take some time from what I read!)
    Wouldn't attempt a cambelt change though but phone around, the garage I use in Northampton are very reasonable for most things.
    Jul 2009
    Milton Keynes
    Which garage is it? I'm in MK so not far away. Just been out and cleared the drainage hole by the pollen filter. Water has been getting into my heater system. Should not happen again and the heaters appear to be working OK now. But I am worried there is water in the system eating away at the components as I type.
    What do you reckon? Will running the heaters for an hour or so on full heat dry the system up or do you think I should take everything apart and dry everything myself?
    BARNSTAPLE
    "Well as if by magic the heater was working again this morning"........ditto! not sure why, but they've just come back on again.:-)
  1. Heaters/Blowers Only Working on No. 5
    By Madison5 in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2013, 00:47
  2. resister for blowers
    Last Post: 6th August 2011, 12:33
  3. blowers
    By bown in forum Introduce yourself.
    Last Post: 9th November 2010, 22:42
  4. blowers and ac blowing hot air
    By Baz4u2me in forum Vectra C / Signum Troubleshooting
    Last Post: 27th January 2010, 15:17
  5. my blowers
    By stuee in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2008, 12:39
