Thread: Sounds like budgies in my boot!!
    Regular Member baz_rochdale's Avatar
    Sep 2009
    Rochdale (Lancs)
    Engine : 1.9Cdti
    Mileage : 118000
    Question Sounds like budgies in my boot!!
    Sounds like i have a budgie in my booty when i drive and cant find the problem anywhere, wheel screwed in fine and nothing in the boot at all!
    anyone had this problem and know where the fudge its coming from,
    Thanks!
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    It could be the rubber bungs on the back edge of the parcel shelf, presuming that you have a hatchback.
    Take it our for a run without the parcel shelf.
    Cambridgeshire
    Exactly the same problem I had and here is what you need to do to shut it up
    Couple of bits of sticky velcro or sticky foam/pads on the bump stops of the tailgate struts:
    Then peace and quiet
    HTH's
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Can't you just screw the rubber stops on the tailgate out a bit more?
    Sep 2009
    Rochdale (Lancs)
    Engine : 1.9Cdti
    Mileage : 118000
    sweet. i'll try them both and see how i get on. many thanks!
    Still got a problem on my side skirt, its a topic in this forum section.
    Regular Member Kickdown's Avatar
    Nov 2009
    Durham, UK
    I had a similar problem but the rubber buffers were not to blame on mine.
    There are another two plastic buffers that 'catch' and guide the boot lock and I simply applied some lubricant to them as they were rubbing very slightly when driving causing the sound you describe.
    Work a try I think.
    Regular Member P3tchy's Avatar
    Milton Keynes
    Sweet, I have the same (among other) issues. Thanks guys.
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by parsco View Post
    HTH's
    just curded my squeaking noise with this excellent tip and it only cost 99p barrrrgain!!! and no more stress when driving as the noise was doing my head in.
    Blantyre
    Quote Originally Posted by Ste View Post
    Mine threaded, now there pushed all the way in dont unsrew them to much or thats what happens
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Mine have broke... how much are replacement, or anyone have a bodge idea
    They just push in and out at min even when turned into the lock position...
  1. sounds
    By grumpy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2009, 11:35
  2. Flat battery and cicking sounds from fuseboxin boot
    By Stevo K in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2009, 15:18
  3. this sounds
    By dave16v in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2008, 21:42
  4. What sounds the best.....
    By BigMan in forum The 'Off Topic' room
    Last Post: 22nd September 2008, 19:26
  5. Sounds Like
    By VauxVeteran in forum General Chat
    Last Post: 25th July 2007, 23:37
sounds budgies like
