Results 1 to 10 of 14
Thread: what are the first signs of an EGR valve failing?
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    Default what are the first signs of an EGR valve failing?
    i bought my 1.9cdt club 150 (05) with 101,000 on the clock. i do not know much about cars. bu since joining vectra c owners club ive obviously found out about common faults. as far as im aware the EGR on my car has never been changed or cleaned what are the first signs of an EGR valve failing?
    the only probs ive encountered are very rarely while coming to a junction & engaging the cluutch the revs will drop below 500rpm but return to normal before the engine cuts out. very slight (and i mean very slight not even a mm) rev needle bouncing when cold? and the engine seems to run pretty rough while the air con is on at idle. could this be a sign of the egr on its way out?
    Ashington, Northumberland
    The engine running pretty rough when the aircon is on is a good sign that you need to have the No.3 injector wiring/connector mod done. An EGR that is choked up may cause a drop in power and throttle response. If it gets too bad that it is seized up with gunk and cant work, then it will throw up an EML on your dashboard
    Sep 2009
    swansea
    Trim : Club
    ok mate. starting the car is fine. bit tappy when cold but what diesel isnt. & for the mileage she flys. i drove my old mans mates 09 sri cdti 150 a couple of months back & i could notice hardly no difference in power, just a little smooother.
    would a local garage know how to do this, & roughly how much would it cost?
    also could u let me know if this would affect performance & and/or cause damage if left?
    Regular Member Dazzy2006's Avatar
    Notts
    Dont know about the 1.9cti but on my 2.2dti the egr has had it and i'm looking at £306+vat to have it replaced .
    My tickover kept going up and down,lack of power before turbo kicked in and the eml light was the final give away
    Oct 2009
    North Wales
    Sounds very pricey, my EGR went last year but i found info in this forum and cleaned it out myself, takes an hour or two but saves a fortune. If you're not that confident to recondition you're own a few auction sites have them for sale at peanuts compared to vauxhall dealers.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    dunno if its a common side affect but....
    when mine went i could smell diesel in car when driving now and again
    Sep 2009
    swansea
    Trim : Club
    took the egr off and gave it a good clean today. was caked in crap. i left the solenoid as the pin was moving freely. the intake where the egr bolted to the head was the worst. suprised anything was getting through. the car runs alot smoother now & picks up better
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    i have a 2.0 DTI thats done 136k , do you think id notice a change if iwere to take it off and clean it??
    Sep 2009
    swansea
    Trim : Club
    Quote Originally Posted by SteveH View Post
    might do mate give it a try. only done mine as it was running a bit lumpy and a little slow picking up
    Bristol
    Vehicle : CDTI 150
    Might want to give the boost sensor a clean, there is a how 2, very easy and makes a difference
  1. possible alternater failing?
    By Dane-10 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2012, 18:32
  2. Battery Failing Maybe
    By WeDesign in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2012, 17:03
  3. Possible Oil Pump failing???
    By dtmwelburn in forum Engine & Drivetrain
    Last Post: 11th September 2011, 19:52
  4. Wipers failing.
    By izonoky in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2009, 23:08
  5. cdr2005 failing
    By tarandy in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2006, 20:13
egr valve failing
