Thread: Bumper on or off? . . .
    Regular Member TopRod's Avatar
    Liverpool, UK
    Default Bumper on or off? . . .
    I'm goin to be installing my hid kit in the morning (weather permitting) and I need to know if the light units can be taken out with out taking the bumper completely off. I've got a face lift Vectra SRi, I've found the how 2 on taking the Bumper off but its the pre-face lift Vectra. Does anyone have any info on how to take the bumper either half off or just completely off? Also how many screws are there holding on the headlights? Is it one at the top and one at the bottom? Thanks.
    Regular Member i5aces's Avatar
    andover
    this might not be much help but i did mine today and it was ALOT easyier than i thought, i undid the 2 screws in each wheel arch took the two clips out the top then just pulled it forward enough to get to the bottom screw holding the head lights. i got my kit from hid direct and the metal clips to hold the new bulbs in place needed the wings flattend to secure properly (youll know what i mean when you take the bulbe out) i would recomend taking out the lights as i wouldnt have liked to try get in there while they were fitted and i have hidden the ballasts under the lights you cant see anything thats not oem. the only problem i have is the lights flicker if the engine is on but the lights are not and for a while after i lock the car, i have emailed the company they recomended trying them without the cancellers fitted so thats what i will try tommorow, if you have the same problem it could be worth trying that before you put it all back together.
    Liverpool, UK
    Have you got the face lift? I bought the can bus pro.
    andover
    No mine is the pre face.
    They do look good tho just got back from a friends and the light on the rode is imence
  1. Signum front bumper (Vectra c pre-facelift sri bumper) rubber skirt
    By 2.2 DTI SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2012, 20:23
  2. Replies: 1
    Last Post: 2nd February 2011, 22:32
