Results 1 to 10 of 13
Thread: Quick questions from newbie
    Jan 2010
    Middlesbrough
    Default Quick questions from newbie
    Couple of quck questions from a newbie
    Can you buy the front vent slats seperately as on of my vents has them all missing,
    and
    does the 12v socket in the front have a flap on it, mine has no flap and is faulty, but when i was at the stealers today they said the front one has no flap and they wanted £19+ vat for the socket
    07 reg sri cdti if that helps
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    By 'front vent slats' do you mean the air vents ?
    If you do, do you mean the centre ones or one of the outboard ones ?
    I believe either are replaceable as just the front section with controls and 'slats'. The centre ones come as a pair and form the mounting for the screen.
    Not sure about the front 12v socket, except to say all the Vectra I've seen have had a spring loaded cover flap on both front and rear sockets.
    swansea
    Did the actual cig lighter come with the front socket.
    Jan 2010
    Middlesbrough
    Quote Originally Posted by jrh1 View Post
    No, the front socket comes as 3 seperate parts, not including the cig lighter
    Jan 2010
    Middlesbrough
    Quote Originally Posted by Handyandy-UK View Post
    the horizontal flaps on one side of the centre air vents is what i am after, from the above i take it i need to buy the complete surround
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by 123yka View Post
    If you still have the removed/undamaged bit of plastic you should be able to remove the vent assembly and reconstruct it.....
    ... if not I dare say the entire item would be cheap enough from a scrappy... although get a price from the stealers first - some parts are surprisingly cheap.
    Sep 2009
    Glasgow
    my front and back have a flap.
    Jul 2009
    NEWPORT
    Send me your details i have some spare and i will put them in the post as with the other bits
    Accessory Power Outlet Ring with Cap £1.07
    Accessory Power Outlet Socket £6.08
    Cigarette Lighter Housing £10.89
    Cigarette Lighter £21.00
    Cigarette Lighter Glow Ring £6.50
    All Oem Parts http://www.vauxhallworldparts.com/ne...arch=Yes&vrm=0
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    I changed the cigar lighter socket on my 02 club for a 12v socket instead and bought the socket, a seperate outlet ring with cap but also had to buy the 12v socket surround as the panel around the cigar lighter has a smaller circular diameter than the 12v socket, and the flap on the 12v outlet ring wont open using it.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by Waterboy View Post
    Idle curiousity... but if the aux power socket (lighter socket) worked, why change it ?
    One of the things I noticed in a previous life as a trucker was the incredible lack of devices available for the 12/24v power socket compared to the mass available for the standard 12v socket (then termed 'cigar lighter socket', now referred to as 'auxilliary power socket').
  1. Newbie with a few questions
    By Mattbull86 in forum Engine & Drivetrain
    Last Post: 18th January 2013, 18:47
  2. Newbie with a few questions.
    By SRiTaff in forum Introduce yourself.
    Last Post: 2nd October 2011, 08:40
  3. Newbie with Questions
    By andd306 in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2010, 17:47
  4. another newbie with questions
    By tony stoney in forum Introduce yourself.
    Last Post: 17th May 2009, 01:46
  5. Newbie questions
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2005, 00:08
