Results 1 to 10 of 20
Thread: Air vent broken
    Oct 2009
    Northumberland
    Default Air vent broken
    My drivers side air vent is broken. The bottom slat has come out of the holes which hold it in place. It is ok when the vent is open as I can wedge it so it doesn't drop, but when the vent is closed, it drops to the bottom and leaves a gap.
    I have tried for ages and can't fix it while in situ. How difficult is it to remove the vents, is there a guide?
    Regular Member Ademusic's Avatar
    Dunstable
    Just pull the plastic trim below the airvent away from the dash, it's a bit tight, and there are only 2 torx screws that hold the vent in. Dead easy to remove once you get the silver plastic trim off!
    Regular Member mhvcbv's Avatar
    Sep 2007
    cambs
    hi m8
    if the bottom vent is broken then thiers a good chance that the fin carrier has snapped and you will need another whole airvent.
    Dunstable
    It's a common problem as the plastic guide for the slats is pretty thin, i've had the same thing on both the vectras i've had, you CAN repair it by removing and dismantling the vent, I've used araldite to repair the break, superglue isn't strong enough to hold, or you can just buy a second hand vent to replace the broken one...
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Finding second hand ones anywhere near Derby is like trying to find rocking horse poo!!
    Dunstable
    The easiest place to find one is on ebay if you have access to it. They're always coming up on there, though fixing it should be simple enough.
    Regular Member wardy's Avatar
    Chichester
    Quote Originally Posted by mhvcbv View Post
    hi m8
    the carrier was also broken on my 05 sri, but I repaired it. Used a heated screwdriver to melt the plastic together & heated the end of a paperclip & pushed into the end of then vent, then cut to correct length to replace the hinge pin on the end of the vent.
    Worked fine for me & worth a go before you buy a replacement. Lasted months and as far as i know still working, as i've sold the car
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    2 of mine have broken on the bottom due to my 3 yr old
    i rekon u could superglue it.
    they arent v good i must say. very cheap & flimsy design
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Vehicle : Vectra C Estate (150) Nav
    Engine : 1.9 CDTi (150)
    Mileage : 126000
    Carefully prise/pull off the trim and you'll see this:
    The two screws are obvious. This is what it looks like with the vent (and lights module) removed:
    Hope that helps!
    Chichester
    Quote Originally Posted by Ollie View Post
    Hope that helps!
    see what?
  1. Front vent broken
    By Kev_1664 in forum Bodywork & Interior
    Last Post: 3rd March 2011, 16:36
  2. Broken air vent
    By Lao in forum Bodywork & Interior
    Last Post: 4th May 2010, 21:20
  3. my center vent is broken
    By Morephun in forum Bodywork & Interior
    Last Post: 9th May 2009, 12:40
  4. Dash air vent broken....help!
    By TonyR999 in forum Styling
    Last Post: 16th November 2006, 22:59
https:www.vectra-c.comforumshowthread.php99765-Air-vent-broken
vectra c air vents
vectra c vent fix
vidio ceramh venting nya slat 3gp
vectra c passenger air vent
vauxhall vectra fix air vent
Vectra c replacement vent fins
how to remove vectra c heater vent
vauxhall vectra c air vent removal
air vent removal vectra c
Vectra c vent broke
vauxhall vectra 2007 vents repair
vectra c air vent broken
drivers side vent remove vectra c
opel vectra c air duct stl
