Thread: Boost sensor?
    Regular Member Dazzy2006's Avatar
    Notts
    Default Boost sensor?
    Can anyone tell me where the boost sensor is on a 2.2dti? (i keep reading it gets clogged up and needs cleaning but i dont know what it looks like or where its fitted )
    Also is there anything else that might need cleaning or is prone to pack up as im having the egr valve replaced next week so i dont want anymore problems after thats done.Thanks
    Regular Member eaglepva's Avatar
    Up North
    Notts
    Thanks - is it easy to remove and is there anything else thats work checking
    Up North
    think i used a 10m ring spanner to loosen the nut then used my fingers to finish it off. then just pull the boost sensor out. i sprayed it with carb cleaner and used the little ones toothbrush then re fitted it. takes about 10mins
    Notts
    Quote Originally Posted by eaglepva View Post
    Cheers - i'll add that to my list of jobs to do this weekend
  1. boost sensor on the 120
    By SarahP in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 22:25
  2. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
