Thread: misfire / judder
    Regular Member Graeme01's Avatar
    Aug 2009
    wirral
    Default misfire / judder
    got a 150 cdti and this morning turned it on and it was coughing and spluttering whilst on idels and the spanner light coming on and off. left it and got a ride to work and just come in and its doing the same thing again ( was hoping the fairy's would have fixed it) but no such luck.
    when i take it for a drive it runs alryt but splutters sometimes at higher revs but not as much and then just sounds like a misfire on one of the cylinders at idle?
    any ideas?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    3rd injector, EGR valve..?
    This is usually down to the 3rd injector wiring, remove the engine cover, unplug the 3rd (3rd from the left as you stand infront of it) injector wiring plug, spray a little bit of WD40 in there, then connect, disconnect, connect, disconnect a few times and see if that makes a difference, if it does then you will need the new plug, about £12 from VX.
    Kingston Upon Hull
    This is very intresting as my car is doing somthing very similar when i start it from cold it seems to start on 3 cylinders but when i rev it it clears and runs on 4 it also judders untill it warms up
    Its a cdti150 only done 34000
    Jacko
    Aug 2009
    wirral
    ok will check the third injector tnyt! Is the third one the second from the left as you look at it from the front of the car or the second on the right?
    Kingston Upon Hull
    Number 1 is the cam belt end so that makes it 3 from left if that helps
    Jacko
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    See this pic
    Mine has had the 3rd injector fix - and you will note that the plug is different.
    Still not heard any conclusive reason why only no.3 - apparently its due to heat flow over that plug - but I am not convinced..
    Aug 2009
    wirral
    Quote Originally Posted by AntSSSS View Post
    See this pic
    cheers for the help just cleaned the injector and its running a lot better with no spanner light so at least i know its that!
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Graeme01 View Post
    the modded 3rd plug + Loom kit is 12 quid from vx and there is a how to on changing it i believe..
    A
    Aug 2009
    wirral
    A
    yeh ill buy it at the wknd and fit anyway as dont want it to fail at an awkward time
  1. Judder and eml
    By Lordish in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2012, 07:41
  2. Insignia blip/Misfire/judder ?
    By bigmac in forum Engine & Drivetrain
    Last Post: 25th July 2011, 22:46
  3. Judder in 1st
    By jongiddings in forum Engine & Drivetrain
    Last Post: 19th March 2011, 17:04
  4. 2.2 direct judder / misfire
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2009, 13:12
  5. judder
    By twaiter in forum Engine & Drivetrain
    Last Post: 14th July 2009, 21:26
