Results 1 to 10 of 11
Thread: Incorrectly wired intermittent wipers?
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Engine : 1.9 CDTi (150)
    Mileage : 126000
    Default Incorrectly wired intermittent wipers?
    Hi all,
    I've not checked the manual but, unless I'm being a bit thick, I would have expected that the smaller the bar (ie to the left) the shorter the delay, the longer the bar (ie to the right), the longer the delay. Mine is wired up the other way round and I am just wondering if this is a Vx 'standard', or if it's pot luck?
    This was also the case on my previous Volvo and Daewoo, so am I mistaken or just plain unlucky? Also, is it possible to correct this and get them wired correctly?
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    i believe the intermittent setting is rain sensitive, mine is anyway. and i always thought the bars are how sensitive it is.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Ollie. Mine behaves in the same way, ie move to right for less delay between wipes. This is the norm.
    As every car you've had was the same as this, I think you are reading it wrongly. Bigger bars = more swipes per minute....
    Nottinghamshire
    As above...
    If you have rain-sensitive wipers, they are less sensitive with the lever over to the left and more sensitive with it over to the right.
    If you don't have rain-sensitive wipers, the delay between wipes is longer with the lever over to the left and shorter with it over to the right.
    Edinburgh
    I thought rain sensitive ones didn't have the "level" on top at all? You set them to intermittant and the rain sensor controls the speed?
    mine are rain sensitive and have the dial on top
    West
    Quote Originally Posted by Big Knox View Post
    The controller on the top is for the intermittent control of the rear & to control the rain sensor.
    Wales, UK
    Yep to the right on a non-sensing car is for quicker wipes...
    Yes they do, as already posted it changes how sensitive the sensor is.
    Jan 2010
    Towcester
    Mileage : 126000
    Thanks for all the replies guys!
    I don't have rain-sensitive wipers. There are (just) 4 settings in all and they adjust the intermittent timing of the wipers front and back (if it's on).
    I guessed that this would be 'as expected' and I guess I'll have to accept the 'bigger bars'='more wipes' reasoning. Displays and controls always run from L-R or clockwise so I guess what they mean then is that when there's a big gap, even though the actual speed of the wipers in operation is the same, the rate is 'slower' and that when there's a shorter gap between wipes the rate is 'faster'.
    Thing is, I consider myself to be a logical person and personally I'd argue that it's non-intuitive and doesn't make any sense. When talking about intermittent wipe, I've always perceived the marking to be referring to the gap rather than the rate. I would guess that the original thinking behind this comes from the US(?); maybe their brains work differently, or is it just me that thinks this is a bit odd?
  1. front wipers not working on slow or intermittent
    By aconway in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2011, 14:13
  2. No Intermittent Wipers Until 60mph!
    By cold-chilli in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2011, 21:37
  3. windscreen wipers on intermittent
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 11:18
  4. Intermittent wipers: How do they work?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2006, 18:45
