Thread: Indy in Liverpool to replace window regulator
    Nov 2009
    Liverpool, UK
    Default Indy in Liverpool to replace window regulator
    Window regulator went this morning....
    All mangled and bent inside the door...
    VX want £77 for the part ant £132 to replace.
    Is that reasonable? Any indys around Liverpool/Bootle??
    Peter (Driving home in the snow tonight with no window!)
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Can you DIY? It's not difficult to change the mech.
    Can you close the window manually and wedge it up in the closed position? I had to do this with a MK 2 Astra when I was a student, until I could replace the mech.
    Nov 2009
    Liverpool, UK
    I cant get the window that far up....
    I tried but it was just bending the mechanism more.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Can you temporarily detach the glass from the mech, it would need to be done anyway for mech replacement.
    ebay for a replacement?
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...item3efbe7bb43
    Here is the only How 2 I could find. It is for fitting electric rear mechanisms, but the principles of removal and refitting the front mechanism will be similar.
    http://www.vectra-c.com/forum/showth...ghlight=window
    Nov 2009
    Liverpool, UK
    I got the window back up by pulling and pushing...
    Can see where the mech is bent...
    So do I need to drill the rivets out to get existing part out, and then re rivet a new one back in.
    Will that Vectra C one fit the Signum?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I assume they are exactly the same, as the front doors are. His phone number is on the ad, so may be worth confirming.
    If you already have the door card off, then fitting a new mech would be easy. Just unclip the wiring, drill out rivets and remove (disengaging from window runner too)
    Nov 2009
    Liverpool, UK
    OK...
    I'm going to DIY it!
    Pick the part up later and do it this weekend... what tools will I need?
    • A rivet gun
    • Drill
    • Torx 20 Screwdriver
    What else?
    Are there any better instructions anywhere?
    How do I get the glass off the mechanism?
    Peter
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If it's like other cars, the mechanism had a slider along the bottom of the glass runner and will simply slide off the end once the rivets ahve been drilled off.
    I don't know what specific tools you will need other than what you have listed.
    Nov 2009
    Liverpool, UK
    All sorted...
    Guy who I bought the part off, fitted it for me for £30!
  1. Window regulator is same or different ?
    By SandyGBR in forum Bodywork & Interior
    Last Post: 21st September 2011, 12:03
  2. Window Regulator
    By manimal in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2010, 14:32
  3. Window regulator?
    By dh.dti in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2009, 12:52
  4. OSF WIndow regulator
    By addyboy1982 in forum Parts for sale
    Last Post: 6th June 2009, 13:40
vauxhall vectra c how to fit regulator
