Thread: Advice please!
    New Member venom's Avatar
    Nov 2009
    Suffolk
    confused Advice please!
    2006 Facelift 2.0 sri Vectra C - looking to see if anyone can help with advice about how I adjust the headlights main beam.
    I have got the dipped beam aligned perfect and with the recently installed HIDs have no doubts it was money very well spent (thank-you Santa ) but the main beam is shining way too high and my question is - can this be adjusted seperately or will I just have to put up with it?
    I've checked the bulbs and these are fitted correctly and I know that with the headlight adjuster inside the car it effects the entire light unit, but on my car the main beam is so far out I'm thinking there MUST be some way of lowering/adjusting it without having to adjust it from inside and then effecting the dipped beam HIDs.
    Regular Member eaglepva's Avatar
    Up North
    Bump
    same problem for me.
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Whats the difference with yours. a few inch is normal...
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Way too high ??
    I thought the only 'aimable' lamps were the dipped beam - the reflector assembly being a rigid item so the positional relationship between dip and main would be fixed.
    So assuming the lamp mounts are securely fixed to the reflector assembly and the dipped beam is correctly set, I wouldn't be too worried about the main beam as long as it's pointing pretty much straight ahead.
    Of course I could be wrong
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    The Main beams can be adjusted using the alan sockets same as the dips. I think the dips are the inboard sockets and the mains on outboard or vice versa..
    HTH
    Stuart
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    As you know the adjusters are the white allen key sockets adjusters through the access holes on the top of the front member above the radiator, outside lamps's are aways the dipped and the inner lamps always the main beam. I think ani-clockwise raises it, if I remember correctly but not 100% sure. Best to place the car against a wall or garage door and mark current position so you can tell how far you are moving it. Just a couple of minutes job.
    I no longer have a VX car, so cannot remember if there was an adjustment for both dipped and mainbeam, its possible that Handyandy-uk is correct and there may only be the one adjustment for both... memory's not so good these days..lol. I have a feeling that there were 2 holes either side but one of them may have been for horizontal adjustment.
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    go m.o.t station they will sort it out
    11 Post(s)
    Quote Originally Posted by 67688c View Post
    As you know the adjusters are the white allen key sockets adjusters through the access holes on the top of the front Member above the radiator, outside one's are aways the dipped and the inner ones's are the main beam.
    No they're not. The inner of the two adjusters raise and lower the lights. The outer screws are for the horizontal adjustment.
    If you raise the height of the dipped beams, the high/main beams also adjust as well as they're in the same light unit. There is no separate adjustment for the high/main beam.
    Apr 2008
    In UK
    Thats what I suspected may be the case, I actually meant the lamps, but you posted while I was editing my post...lol Sorry if I caused any confusion, and thanks for ellaborating, its been about 2/3 yrs since I play with them.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    You mean I was right after all ??
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
