Results 1 to 10 of 19
Thread: Fitting towbar to Vectra C
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Fitting towbar to Vectra C
    Could really do with some pics of exactly where they bolt onto the car, from inside the boot area, and from below.
    Any advice.
    Also what do I need to complete the wiring?
    It is an aftermarket type, with twin electrics. Was just going to cut into the existing wiring loom, and there you go. (like on my old vectra). Not sure if it would cause issues elsewhere though. Buzzer for the indicator telltale, and relay for the FRIDGE, +12V and AUX included.
    TIA
    Try searching for your car here:
    http://www.witter-towbars.co.uk
    They've got installation instructions as PDFs. (I'm guessing that all towbars use the same mounting points irrespective of make).
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Spot on. thanks
    Leicester
    I have fitted one to mine with both electrics, be carefull when cutting into the loom, it will set offvarious fault codes. When I bought mine, it came with a black box which prevents this from happening.
    I take you have your answer? Let me know if you are still stuck.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Matt, the wiring is the thing that is concerning me.
    I have tried adding another bulb to the indicators and to the side light / brake light. (using a piece of wire and a bulb). Only on the passenger side though.
    Nothing happened, except of course the bulb illuminated.
    As the side lights operate on reduced voltage, and full voltage for the brake light on the upper side light, they cannot even operate a standard relay.)was going to use this to power side lights.
    What does the black box do? Where does it connect? Is it into the pass side electric distribution box behind the boot trim?
    Where do I get the main power feed (easily) from for the secondary towbar plug? Don't want to run an other wire from battery.
    Info would be greatly appreciated.
    Ste
    Sep 2010
    lincs
    my cars a dualfual vectra 53 plate with the lpg tank in the spare wheel 1.8 club car is it possable to fit a towbar please
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep as the towbar bolts into the boot floor at either side of the wheel well
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Jeez, this thread is over 5 years old.
    Mileage : 000
    I take you have just finished fitting the tow bar then.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yep, took a while, but it's now all working fine. Had to get mate to help me too, or it would have taken a bit longer.
  1. Towbar fitting.
    By burbling1 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2012, 16:59
  2. Towbar fitting
    By KTM Chris in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2012, 21:08
  3. towbar fitting
    By derby4life in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2009, 11:04
  4. Towbar question regarding fitting
    By cheekylemon in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2008, 16:45
  5. Fitting a towbar to vec c sri
    By speedo in forum Bodywork & Interior
    Last Post: 2nd May 2007, 07:38
https:www.vectra-c.comforumshowthread.php997-Fitting-towbar-to-Vectra-C
vectra c towbar fitting
how to fit towbar to vectra c
vauxhall vectra c towbar fitting instructions
how to wire towbar on vectra c 082005 vauxhall vectra towbar fitting instructionsvauxhall vectra towbar fittinghow to fit towbar vectra cvectra c towbar installedvectra c adding twin towbarfitting towbar to vectra chow to fit a vectra c towbar how do you fit a tow ball to 2005 vauxhall signum how to fit a towbar to a vectra cvauxhall vectra how to fit towbarsaab tow bar fit vectra cfitting a towbar on Vectra cvectra c facelift towbar www.vectra-c.comfitting a towbar to a 2006 vectra life
