Thread: 2.2DTI Problem
    Regular Member Dazzy2006's Avatar
    Notts
    Default 2.2DTI Problem
    I thought things were going too well , spanner light came on and car went into limp mode so i ran it to a mates to get the codes read and he reckons that the egr valve has had it.
    Does anyone have a rough idea on the price of a egr valve including fitting
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have you tried cleaning the egr valve? That is a common fault on the DTi's
    Notts
    No - i never knew i could, is it hard to do
    I just assumed that when i was told it was broke that i had to fit a new 1. The car runs fine when cold it just seemed to get the fault when the temperature gauge started rising, is that normal ?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Daz
    no it's not bad just a bit fiddly.once you have removed the engine upper cover and the wiring connector'and two small coolant hoses there are only two bolt's to remove.you will need brake cleaner or carb cleaner and a small wire brush
    Notts
    Thanks guys, you have probably saved me a fortune. I just found the how to guide so i guess i know what i have planned this weekend.
    Notts
    Well i just got a nice shock - the person that sold me the car is footing the bill for a new egr valve to be fitted
    Jul 2009
    Engine : 20 Dti
    get the old unit back dazzy give it a good clean , ready for next time.(there will be one!)
    Notts
    Quote Originally Posted by jonnybravo View Post
    I intend to jonny after seeing how much one of these egr valves cost , besides should come off easier after they replace it
  1. Starting problem 2.2DTi
    By Mogsy007 in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 13:24
  2. MaF problem. 2.2dti
    By fuzzyllogik in forum Engine & Drivetrain
    Last Post: 14th July 2012, 15:12
  3. 2.2DTI SRI Exhaust Problem
    By Dazzy2006 in forum Engine & Drivetrain
    Last Post: 4th February 2010, 14:54
  4. 2.2DTI Elite - Air Con problem???
    By martyn_bannister in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2009, 21:20
  5. Confused 2.2DTI Problem
    By kraviz in forum Engine & Drivetrain
    Last Post: 4th April 2007, 06:57
