Thread: Trip Computer on an SRi
    Regular Member joejdx's Avatar
    Glasgow
    Question Trip Computer on an SRi
    Hi Guys,
    Just a quick one ... does anyone know how accurate the trip computer on the Vec SRi is?
    More specifically the "Range" function.
    Thanks,
    Only accurate as far as your previous 30 miles of driving, as that's what it's based on mate. Rely on the guage, and when it starts getting close to the red you should start to think about filling up... After you've filled her up to the brim fro the first time you'll get an idea how far from the bottom of the tank the last mark actually is, and you can judge it better from there...
    Tank is 60 litres...
    Regular Member sri andy's Avatar
    Apr 2009
    Lancs/Manchester
    I always fill up when it says 0 miles till empty! never run out before that point yet.
    Ireland
    Quote Originally Posted by sri andy View Post
    Mine never goes to 0, it goes to about 17/18 then --- then after about 2 more miles the fuel pump lights up ?
    Wales, UK
    lol !! 0's a bit low, I always fil up before it even hits red but once, Ive rolled into the station forcourt with 4 miles showing, so I guess its reasonably accurate. Still not worth the risk !! lol
    You cant always rely on the guage. I found this out when my 2.2 suddenly stopped with a 1/4 tank !!
    Full Member
    Bristol
    The trip computer on car is accurate but as close as it can be. The trip computer is run off the abs system and not the engine. It is only a guide.
    Regular Member H15 VXL's Avatar
    aberdeen
    the last time i got fuel i had com reading 11miles and light just came on it took about 54ltrs to fill and it is 60ltr tank. car is 2.2 sri
    I don't use the RANGE, my display is set to average MPG
    I usually refill the fuel tank when the needle is down to the last eighth as that is about 7 litres / 30 to 50 miles
    However, the "RANGE 30 miles" display usually overrides if the needle gets this low
    I can then extend the range by trying to keep the speed between 40 and 60mph
    Quite often the RANGE then disappears
    However the fuel tank warning light then comes on, then I know I need to refill and usually by the time I do find a PFS the warning light has started to flash
    I have looked a few times at RANGE, but on refilling it can be anything from 250 to 500 miles
    On the 1.8 the RANGE is not likely to be as volatile
  1. trip computer..
    By djdee in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2011, 12:53
  2. Trip Computer
    By Matt Cutler in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2009, 22:27
  3. anyone added trip computer/board computer?
    By Craig1985 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th August 2008, 02:33
  4. trip computer
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2008, 19:22
  5. Trip Computer even possible?
    By delete2 in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2008, 01:00
