as above i turn it to cold and it still blows warm
have you changed the led's in the heater control panel if so strip it apart again and check the position of the dial. if not then i'm useless i'm affraid but a free bump.
Dodgy servo?
where are the servos
behind the footwell kick plates - behind the centre console. Engine off, ignition on, fan off, move the temp control, you should be able to hear them move, but they are very quiet.
See if you can hear it move first as stated above. If not or if it still won't blow cold air, then then it's called the mixed air valve servo motor and is located on the left-hand side of the heater unit.
For easy access, take the glovebox and the footwell trim panel out (the one next to the passenger's right foot) and you'll see it there. You might get away with just the footwell panel to get a look at it and see what the problem is, but it might be an idea to take the glovebox out for access if you have to start working on it.
The unit is black and has a wiring connector plugged into the bottom. It has plastic 'wheel' on the front with a plastic arm attached to it. It also has some passing wiring secured to it by a plastic clip.
The wheel should spin round and move the arm when you turn the hot/cold dial on the heater panel.
thanks i will have a look and post back
