Results 1 to 10 of 11
Thread: 2.0dti turbo question
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default 2.0dti turbo question
    CAN SOMEBODY TELL ME IF I HAVE A SPLIT IN THE PIPE (SEEN IN PIC) GOING FROM ENGINE TO TURBO WILL IT EFFECT THE TURBO PERFORMANCE?? BECAUSE I HAVE A SMALL AMOUNT OF OIL LEAKING FROM IT, THERE A SLIGHT SLIT AND AT THE END OF THE CLIP ITS SPLIT, WHATS THE PIPE FOR????
    Nottinghamshire
    That's one of the 3 flexible pipes between the turbo and the engine, so yes it will cause boost problems - it is letting out air that should be going into the engine.
    You may get the 'car and spanner' light come on under acceleration and the fault would be something like 'boost pressure out of range'.
    You can see the other 2 pipes at the front of the engine bay - one connects from the solid metal pipe that runs over over the top of the engine (the one disappearing under the plastic engine cover at the bottom of your picture) to the offside end of the intercooler (the radiator at the front that cools the compressed air before it goes into the engine) and the other runs from the nearside end of the intercooler into the inlet manifold at the front of the engine.
    Check all of these pipes and check they are all intact and properly secured at the ends. Tighten any loose jubliee clips and replace any damaged pipes - you can get silcone versions of the 2 long pipes from eBay. Not sure about the short one. I think dealers sell them together but again I'm not sure if that's just the 2 long ones or if it includes the short one as well.
    Oct 2009
    Sandwell
    Quote Originally Posted by james24 View Post
    that's one of the 3 flexible pipes between the turbo and the engine, so yes it will cause boost problems - it is letting out air that should be going into the engine.
    Check all of these pipes and check they are all intact and properly secured at the ends. Tighten any loose jubliee clips and replace any damaged pipes - you can get silcone versions of the 2 long pipes from ebay. Not sure about the short one. I think dealers sell them together but again i'm not sure if that's just the 2 long ones or if it includes the short one as well.
    cheers mate, that will explain why the turbo dont seem as good, i only noticed it when i was doing my glowplugs and had to remove it , its got a split in the centre and there seems to be a peace of plastic on the pipe for the clip but thats coming away from the pipe,,,,,
    Nottinghamshire
    Good luck getting a new one. You should find performance picks up once it is replaced. Check the other 2 larger pipes as well and replace them as well if necessary.
    While you are at it, you could also check the thin vacuum pipes and their rubber end pieces. Any air getting into these can cause problems because the valves that the vacuum operates won't move as they should. The pipes and rubber end pieces are available by the metre from dealers.
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    mine had a split in one of the boost pipes. dont buy a new one from VX, its around £80 for three, two you dont need. if you want i will send you some shrink tubing that i have used on mine. its done 10Kmiles now and no probs at all. if you want to try some send me a PM!
    mick.
    Regular Member eaglepva's Avatar
    Up North
    Where do you buy the shrink tubing from mate,
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    samco hoses work a treat mate
    Oct 2009
    Sandwell
    Quote Originally Posted by mick 1986 View Post
    mick.
    thanks mate ill pm you, i brought some tape today to go around the pipe it does seem as if its working to some point but i need to get it replaced, also i checked the pipe and it did have a GM number on it so i rang vx up and the bloke goes no mate there isnt a part number for, but there clearly is a GM part number on it,
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Quote Originally Posted by eaglepva View Post
    i get it from work mate for free!
    PM if you want some?
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by paulvectrac View Post
    Didn't think you could get them hoses for vectra
    Irmscher Insignia CDTI 130
  1. Turbo problems on my signum 2.0dti
    By cookieboy in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2010, 12:54
