Thread: Vectra C 2004 advice
    london uk
    Default Vectra C 2004 advice
    Hi everyone ,
    I have a vectra c '04 diesel 1.9 hatch
    and i would like to change the shock absorbers.
    What brand would you suggest i should go for?and do i have to change the springs also ?because i read in different posts that people who changed the shock absorbers only they had problems.
    Could anyone please advice me on what to do?and roughly how much money the parts would cost me.
    Regards
    George A
    cambs
    hi m8
    go for the b4 shocks and eibach springs(-30mm)
    and i would change the springs aswell, seing as the shocks are off anyway.
    cost me about £300 for shocks and springs
    london uk
    Default Vectra C springs
    on the springs it gives me couple of options for the weight on the front and back of the vehicle?
    how do i know which one is the correct one?
    can anyone please help
    newcastle
    Is your car an sri. The standard sri struts are 20mm shorter. On previous threads on the forum it has been said than you can stick 30mm lowering springs in without replacing the struts. Anything more than 30mm you will have to replace the struts.I drive a 03 dti and put lowering springs out of a written off 1.8 veccy c. dropped a good 60 mm as the dti is a heavier lump. put standard astra springs in the back to even the car out
    cambs
    Quote Originally Posted by george120879 View Post
    have a look on the drivers door pillar and it will tell you the weight
    Sep 2009
    Fleet
    Guys, I too have a 2004 sri cdti 150. any suggustions on good priced shock dealers.
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Eurocarparts.com are cheap for billys.
    Worcs/Staffs/Westmids (ish)
    Quote Originally Posted by mhvcbv View Post
    hi m8
    This is what I did and you really can't beat it for the money.
    Set of Bilstein B4's + Eibach springs
    The standard shocks are rubbish, the standard springs rubbish, known for breaking and more expensive than aftermarket ones.
  1. Vectra C 1.8LX 2004
    By Riches in forum Engine & Drivetrain
    Last Post: 15th August 2012, 09:44
  2. 2004 Vectra SRi 20r
    By chrisgriffiths in forum Introduce yourself.
    Last Post: 12th June 2012, 12:47
  3. 2004 vectra
    By mickyamyam in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2012, 16:27
  4. Replies: 6
    Last Post: 27th August 2011, 22:12
  5. Replies: 22
    Last Post: 30th July 2009, 14:15
