Results 1 to 10 of 11
Thread: "Spanner Light"
    Regular Member elkesprint's Avatar
    York
    Default "Spanner Light"
    Hi Guys
    Well took the car out for a spin this afternoon and the dreaded spanner light came on on start up
    Then after about 2 mins in went off
    Now when I turn the ignition key the spanner light comes on then goes off when the engine is fired up and running I tried this a couple of times and the same thing happens
    Any suggestions as what's causing this?
    Cheers Elkesprint
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    70 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Glowplugs ?
    Irmscher Insignia CDTI 130
    York
    I did wonder about the glow plugs....I did the heated Washer jets on Sunday do you think that may have something to do with it ?
    Regular Member LJ sxi-nav's Avatar
    Winchester
    If the spanner light is going out immediately after start-up a previous fault has been recorded which is no longer present. The light will clear itself after a certain number of trouble-free starts, and it could have just been a glitch. If the fault reoccurs then the light will obv. not clear itself and you'll need to get the codes read to know where to start looking.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I don't think there is much merit is guessing what has put the warning on. If it comes on continuously, then get the code read. If it keeps going off after a few seconds then it will eventually clear, or you could try disconnecting the battery for half an hour to see if it clears.
    York
    Me again.
    Used the Vec a couple of times today,on start up this morning the light came on again went out after about 5 mins. Other times when started it has gone out as soon as the engine fires.
    Car always starts on first turn of the ignition after the glow plug light has gone out, and runs perfectly it's just the light that's annoying
    Hi Ste,
    I'll disconnect the battery tomorrow and see if that clears the fault code.
    Elkesprint
    York
    OK,
    Spanner light still lighting up and after a couple of mins goes off.
    I have tried disconnecting the battery and reconnecting an hour or so later and The light still comes on!
    Other than that the car runs perfectly
    Any other Ideas before I go to the dealers
    Not sure if I mentioned the cars 05MY 1.9cdti Elite Estate
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You need to get the code read, it could be simple or expensive. I think guessing could be counter productive.
    You don't need to go to the dealer to get the code read. Are you in AA / RAC etc? They can do it for you, just ring up and say there is a problem with the car and the light is on and that it isn't running quite right....
    York
    I'll give that ago me thinks!
    Update later..
    Elkesprint
    Regular Member nigec's Avatar
    barnsley
    Ive just started getting the same, spanner light coming on from start up, then going off after about 5 mins, then hats it until start up again. Not noticed any problems with car whatsoever, thought it might be down to weather.
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. 1.9 CDTI 150 "spanner light"
    By flyinggazza150 in forum Engine & Drivetrain
    Last Post: 14th November 2010, 14:36
  3. wheel quiz "win a alu billet tee light holder"
    By speedzone in forum Styling
    Last Post: 29th April 2008, 10:59
  4. Spanner light on dash - "self test"
    By 24vElite in forum Engine & Drivetrain
    Last Post: 23rd March 2008, 20:21
  5. The "flashing car picture with spanner through it" light
    By Big Dave in forum Engine & Drivetrain
    Last Post: 9th February 2008, 04:33
