Results 1 to 10 of 18
Thread: Brake pads and discs : 2005MY 3.0 V6 CDTI
    Default Brake pads and discs : 2005MY 3.0 V6 CDTI
    My local dealership has been trying to order brake pads and discs for my 2005MY 3.0 V6 CDTI for three weeks now
    The last two orders have been with the wrong discs, this is a common problem and even though I do ask them to make sure BEFORE ordering they still receive the wrong size pads and discs!
    They also noted the part numbers keep changing, as the service history wwas printed off so that the correct parts could be ordered
    So can someone supply the current part numbers :
    front pads
    front discs
    front pads and discs kit
    rear pads
    read discs
    rear pads and discs kit
    front pad wear sensor
    Once the current set of pads are replaced I am then going to order a complete set of pads and discs sets, plus the sensors, then put this into storage ready for the next replacement (so there is no need to wait for parts)
    Default Supply of brake parts ?
    Is anyone having problems getting orders of brake parts?
    http://www.vectra-c.com/forum/showthread.php?p=1144011
    My local dealership has been ordering 314mm front and 292mm rear discs, for my 2005MY 3.0 V6 CDTI
    However twice now they have received the wrong parts!
    This always happened previously; booked the car in, wrong parts arrived, car booked in again
    This time they checked the parts against the car history, and it looks like the part numbers have changed!
    My car was serviced on 23 December 2009, requiring new front and rear pads
    Inspected my front pads this morning, and there is nothing left on the nearside now
    Regular Member Jezzy's Avatar
    S.E
    Being serious, i.e. not meant as a joke: you need to find another dealer. This is bread and butter stuff....it's like Tesco saying they can't supply semi-skimmed milk because they keep ordering the wrong stuff by mistake.
    Pad and disc sets:
    314mm fronts - 93186299 72 quid + VAT
    292mm rears - 93186301 got mine for 45 quid all in from a dealer through carpartsconnexion
    Quote Originally Posted by Penfold101 View Post
    Pad and disc sets:
    Interesting as I have 314mm Discs ... 93175606 Pads 9318813
    Could this be as you have posted is for a 'set' .. ..................
    Quote Originally Posted by Tadpole View Post
    Yup - these are the pad and disc sets - ie you get both as appose to seperate numbers for them. Both gen as I've used them myself several times...
    Cheers m8 so £114'ish for the front end is that trade or retail price ...............
    72 quid plus vat for the fronts mate, and that's retail price, so about 85 max...
    This has happened three times (this would be the fourth time now)
    The dealership is ordering the parts from the VIN
    I told them last time to look at the previous parts fitted and use those part numbers
    They did both, and the wrong parts have arrived!
    It was the same when they ordered replacement front calipers about four months ago
    From memory the middle size (292 / 288) pads and discs arrive
    I am wondering if the original part numbers are still being used, instead of the actually correct part numbers!
    Slough
    90 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    tadpole (terry) if you want a set of them then give me a shout as think im paying 50 pounds for the disc/pads in 314mm . khalid
  1. Which brake discs/Pads???
    By Coupe2T in forum Handling & Braking
    Last Post: 30th January 2012, 10:18
  2. brake discs and pads
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2010, 16:57
  3. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  4. brake discs and pads
    By vectragsi3.2 in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2008, 10:41
disc diameter vectra c v6 cdti
signum 3.0 which size brake pad
