Results 1 to 10 of 19
Thread: Lambda Sensor
    Regular Member Cat_J's Avatar
    Aug 2009
    Norfolk
    Default Lambda Sensor
    Hello.
    Can't remember if this is my first post so hi incase. Been reading the site for quite some time now.
    I've recently had the engine light come one so I had the codes read (would have been cheaper to buy reader than go to thurlow nunn but oh well, lesson learnt). It turns out the error was from the lambda/o2 sensor although the fault was not present at the time of reading.
    What I need is help finding a new one, probably about time to change it anyway. They quoted me 9158918 for the part number but I cant find that part anywhere. Could someone help me find the part I need somewhere on the net (or less than £145 which is what they wanted)? Its a Vectra C Club 1.8 04 plate.
    Cheers in advance for any help.
    Nottinghamshire
    Have a look for your car at the Partfinder at http://www.ngkntk.co.uk/ if a NGK one will do you. They are a good brand and I never had any problems with the one I fitted to my Astra some years ago. Call your local motor factors or search online for prices once you have the part numbers.
    Note that your car looks to have 2 sensors - one before and one after the Cat - so you need to know which one(s) is faulty.
    Personally, I'd avoid the 'generic' sensors which are sometimes available for slightly less money than a model-specific part. One of these will be OK for your car but will come without the proper wiring connector so you've got to fit the connector from the old sensor to it or snip the connector off the loom and connect the wires directly, or something like that.
    Aug 2009
    Norfolk
    Well its the rear one. Turns out the guy at thurlow nunn gave me the wrong part number. Its actually 9158718. With that its all over the internet.
    Aug 2009
    Norfolk
    Talked to some local motor factors. The small local business wants £65 inc vat, the big nationwide one wants £75. Go small businesses. These prices are for NGK ones.
    There are these on ebay:
    http://cgi.ebay.co.uk/VAUXHALL-LAMBD...7#ht_743wt_802
    http://cgi.ebay.co.uk/Vauxhall-LAMBD...ht_3141wt_1307
    But I don't know what the quality will be like.
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    i might have one can't remember who makes it, unused m8 ....gimme a few mins i'll get back to you
    Aug 2009
    Norfolk
    That'd be cool. Could the weather effect it? Its not come back since it was cleared. Then again like I said its probably worth replacing anyway as it has a effect on economy and engine running.
    Is it an easy job?
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    its a hella part....struggling to find part number on the net to correspond
    HLS116
    6PA 009 166-511 ????
    can anyone find it?
    Nottinghamshire
    Quote Originally Posted by Cat_J View Post
    I'd stick with the quality brands - it's less likely you'll be back under there soon to replace the failed new one. The last one I changed was back in the days when you only had 1 and it was under the bonnet. I had no problems replacing it though so you should be OK if you have the necessary tools and a way of securing the car in the air while you work underneath.
    The recommended way is to get the engine hot then get the car jacked up and disconnect the battery negative terminal. Then trace and disconnect the wiring for the sensor you are replacing before unbolting the sensor itself. Screw in the new sensor making sure the gasket is in place and there is high melting point grease on the thread (good sensors will come with this already smeared on and with a plastic cover over it to stop it getting wiped off in transit).
    Finally torque the new sensor up (the torque setting for both sensors appears to be 30 Nm for the 1.8 petrol engine) and refit/connect the cabling correctly before reconnecting the battery and testing.
    London/Essex
    Gendan Direct are my preferred supplier ...
    Check them out here for direct fit Vauxhall lambda sensors
    Aug 2009
    Norfolk
    That sounds fairly straight forward. Does it go straight into the exhaust? Will a normal torque socket wrench fit over the sensor?
  1. where to buy Lambda Sensor
    By signum04 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2012, 08:56
  2. Lambda sensor
    By danno91 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2011, 16:06
  3. Lambda sensor
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 13:08
  4. lambda sensor
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 18:35
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
