Thread: Idle on startup
    Darlington
    Default Idle on startup
    Hi
    I have a 1.8 Petrol Vectra (06) 27k miles
    Recently when you start it up on a morning the idle will be lumpy, and it will not idle over 600 revs (aprrox) on the display (this morning (not sure about other times)) it will say 8 g/hour where normally it would be 3 and for on a cold morning
    Sometimes the car tries to correct itself and it works ie it bumps up the revs a bit and all is fine, sometimes it bumps up the revs and it just drops down again and keeps trying to do it.
    In all cases a quick dab on the throttle and this sorts it out – and the car in all cases will be fine for the rest of the day.
    Can anyone help me?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Most probably temperature related, hasn't it been cold lately.
    Darlington
    Hi Thanks - I apreciate it has been cold but it did the same this morning, and its warmed up a lot - also my 52 Reg astra never had this issue no matter how cold it got
    Mileage : 000
    Might be the air control valve ?.
    Darlington
    cheers how would i go about checking/replacing that. as it did the same this morning - but after it was sat all day yesterday when i started it after work yesterday evening it started up fine
  1. smoke from cat on startup
    By james walker in forum Engine & Drivetrain
    Last Post: 29th August 2011, 20:17
  2. Startup
    By treasure22 in forum Engine & Drivetrain
    Last Post: 21st February 2011, 17:55
  3. EML On at startup
    By Thebug in forum Engine & Drivetrain
    Last Post: 6th November 2009, 17:34
  4. idle idle? haunted car lol!!
    By 1smokinace in forum Engine & Drivetrain
    Last Post: 27th May 2009, 21:28
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
