Thread: Blower / Heater Fan Problem
    Sep 2009
    N.Wales
    Default Blower / Heater Fan Problem
    Hi guys,
    The porblem im having (which seems quite common after reading this forum) is my heater works fine but blower 1-3 dont work but 4 works perfectly fine.
    I have removed the pollen filter to check if it was dry etc and i also span the motor from behind and its seems free and moving ok.
    When I put the fan on to 1-3 it clicks under the glove box as normal but doesnt work. There is no water damage and all the drains seem fine so its not that.
    One thing I have noticed but thought it was irrelevant a few weeks ago the a squeeking type noice was coming from somewhere near the passenger footwell at the time I thought it was just a leaf, and still maybe, but not sure now.
    Im just wondering:
    A. Which part needs replacing, Ive read about people changin the "
    rheostat" or the "Resistor Pack" or any thing else it might be
    B. Has this part just blown like electronic things do or is there a specific reason and will the new unit just blow straight away if so how do I prevent this.
    Thanks Guys any quick replys would be greatly appreciated as I have today off work to carry out and required fixes.
    P.S. Its a 2004 Vectra 2.0T Edition 100 SRI
    11 Post(s)
    The resistor pack has failed. You can either replace it, or just the thermal fuse (something like 0.79p from Maplins) - which is mentioned in the how2 section.
    Sep 2009
    N.Wales
    Brilliant thank you,
    Any ideas whats caused it to blow and/or if it will blow again ?
    Chris
    Sep 2009
    N.Wales
    Right I have removed the resistor pack and to my untrained eye it looks fine (no burn marks etc) but then again I have no idea , I tried to test the fuse using a voltage testing screwdriver and it light up when I tested it, but im not sure if this proves or disproves any thing. Any suggestions Cheers Guys
    Chris
    Sep 2009
    N.Wales
    Ignore the last post thanks Ive sorted it, it was the fuse as stated cheers guys
    Chris
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    What fuse mate im in the middle of doing a friends now?
    Sep 2009
    Swindon
    the therma fuse that is soldered across the top of the pack is the one you want
    Apr 2008
    Liverpool
    Quote Originally Posted by frenchman View Post
    Cheers mate
  1. Heater Blower Strange Problem - Help!
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2014, 22:38
  2. '02 GSI, heater/blower problem
    By RoddyKFC in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2011, 12:54
  3. Strange Heater Blower problem
    By dickybow in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2011, 22:19
  4. heater blower problem
    By manunut1969 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2010, 02:17
  5. Heater / blower problem
    By lacorbiere in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd March 2010, 14:24
