Results 1 to 10 of 22
Thread: petrol in a diesel engine!!
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    Exclamation petrol in a diesel engine!!
    I made a silly mistake today and filled up £1.12 of petrol by accident but then filled up half a tank with dieselstraight after that went to my local garage to double check everythings ok and they told me its actually good for the diesel engine to mix a little petrol with diesel from time to time, Is this true or will it still do some sort of damage to my engine??
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    yep very true
    even more so in older engines
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    a little petrol wont harm it bud but i would fill the tank just to be sure with diesel this time lol
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I wouldn't say it will do any good to your engine. As you have a high pressure common rail, running on petrol WILL cause damage. However, as you put such a small amount in, it is unlikely to do so.
    I would have filled the tank completely with diesel though.
    WGAF#5
    £1.12 probably only a cup full on todays prices
    seriously though with such a minimal amount i cant see too many problems
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    you should be ok its less than a pint..
    Regular Member yadziyad's Avatar
    London
    you should be fine i think its worse when its the other way around
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by Gr4eme View Post
    It probably just over a litre, so nearly 2 pints.
    Regular Member boba's Avatar
    The Kingdom of Fife!
    It's about a litre at today's prices (1 3/4 pints). You put about 25 times more than this in diesel so you've a ratio of about 25:1 diesel to petrol worst case which isn't likely to bother things too much in the short term. The biggest fear is for the pump to lose lubrication - there should still be plenty.
    Regular Member SRIRob's Avatar
    Jan 2010
    Essex
    That will be fine, I stuck £56.00 worth of petrol in a Kia Sorento once it drove about 2 mails on the A14 then cost the company (lol) £350.00 for the tow in charge drain and flush the tank and new filter, they then put £50.00 worth of diesel in it £456.00 not bad for a silly mistake !!!
  1. Insignia Insignia diesel/petrol engine and DPF question
    By monkeez in forum Insignia car chat
    Last Post: 10th August 2012, 17:08
  2. Petrol in Diesel engine
    By westonprawn in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2011, 21:14
  3. Petrol in Diesel!
    By P-Mutton2.2 in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2009, 06:53
  4. PETROL vs DIESEL?
    By vectrahuw in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2008, 00:07
  5. Petrol vs Diesel
    By kryton01 in forum Diesel Engine related
    Last Post: 14th September 2006, 06:49
