Thread: Possible oil leak from turbo
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Default Possible oil leak from turbo
    Hi, new to the forum, been on VxOn for ages before here. Noticed this the other day, just wondering what it could be, I will try to clean it up to look for any new leaks. Any help appreciated, Gaz.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    first'ly hi! and welcome, thats the under side view of a cdti 150 ??, thats a common leak coming from the turbo / intercooler pipe its oil dripping from the joint mine's been like that from 12months old but its a pig to get to and tighten the jubilee clip, the dip-stick level dont seem to drop at all so i just give it a wipe when i change the oil.
    Jan 2010
    Cornwall
    Hi, thanks for the reply, not too up on turbos, is it air that passes through this pipe? I'll try and clean it up and see how it goes, cheers Gaz.
    Jan 2010
    Cornwall
    Just an update, the garage tightened the jubilee clip as it was a bit loose so we shall see how it goes.
  1. CDTi (120) Turbo oil leak
    By Casey in forum Engine & Drivetrain
    Last Post: 10th April 2012, 20:40
  2. 2.8 turbo oil leak?
    By 2.8 turbo in forum Engine & Drivetrain
    Last Post: 6th October 2011, 09:04
  3. Small Oil LEak @ Turbo. 2.0L DTI
    By mick 1986 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 21:58
  4. cdti turbo oil leak
    By sla002 in forum Engine & Drivetrain
    Last Post: 26th July 2010, 16:04
  5. CDTi turbo oil leak
    By IamtheStig in forum Engine & Drivetrain
    Last Post: 16th October 2008, 20:32
