Thread: Fault codes???
    Nov 2009
    telford
    Default Fault codes???
    Just wondering if the fault codes stay on your car or are they cleared once the fault has cleared, only im having a problem with the spanner light coming on randomly but it clears itself. I have it booked into the garage where i got it from on wednesday but no point if the faults arnt stored!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    when does the light come on?, IE when you start or stop the car or when you are driving along??, if its when you are driving normaly and it comes on and off, don't worry it has rectified its self and not stored a code.
    Nov 2009
    telford
    it comes on when usually when i start the engine. whe i turn the key the spanne light comes on and it will start but then cut out after 3 to 5 seconds.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Luke you should be ok ,a common cause for this scenario is a lazy sensor on one of your glow plugs ,
    Mine has been doing it from the day i got the car , nearly three years ago .
    The light goes out after driving for about 100 yds when ever the engine is cold.
    and still loving it
    Nov 2009
    telford
    usually when i turn ot off and back on it starts again with no light but last night i played football and when i come out to start my car the light was on, tried for 30 minutes but ng. so rang my breakdown company so was out within 30 mins and when they got here start ok no problem with no light. i was gutted
    Engine : 2.0DTi
    Mileage : 73350
    ask if there,s anyone in your area with a tech 2 or an op-ccom who can have a look at your motor
    and still loving it
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    If it's a 1.9 CDTI(150), check the swirl flaps rod is attached to all four flaps, mine did this and I found no2 had come off and no1 had gone the wrong way preventing no3 and no4 from operating correctly. Car ran OK, very smokey at high revs and the spanner light had a mind of it's own!!!
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    EML comes on for me every time I start the car, for about 3 seconds, always goes off though, I was told this wasn't a problem?
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
