Results 1 to 10 of 14
Thread: Should I change oil grade?
    Regular Member mishima's Avatar
    UK
    Arrow Should I change oil grade?
    Hi there,
    It's time to change the oil on the Veccy and just recently after doing a fair amount of millage in one day the oil light came on, so I had to pull into the services to check - the engine was almost empty!
    I had no leak. I used 5W30 last time, is my 2.0 DTI heavy on the oil?
    I'm wondering whether to go for a different viscosity this time - what do you think?
    Full Member
    Bristol
    No stick to 5w 30 . That is what VX recomend.
    Regular Member P3tchy's Avatar
    Milton Keynes
    Go by the book on this one, Very important.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    you have a 02 rg 2.0 dti, whats the mileage?, i used to use normal 15/40 diesel oil and never had a problem for 136k, its not always the oil but a matter of keeping the levels right, changing it early and treating it with respect, ive had lots of high mileage vx diesels and used to only put comma turbo diesel plus in (was only b3 grade which is ok for MOST diesels not having dpf which yours does not have) you can get this from morrisons for about £8 and change it every 5-6k its cheeper and you have cean oil in all the time, i have also done 10k on a regular basis with this oil. just as reasurance for you i put 5/30 for 5-6k then 15/40 in for the next 5/6k i my cdti so 15/40 wont hurt your dti as ive also done 10k with 15/40 oil also.
    Quote Originally Posted by mishima View Post
    after doing a fair amount of millage in one day the oil light came on, the engine was almost empty!
    Planning, planning, and planning
    Prior to a long journey ALWAYS check the levels before, especially on a diesel
    I find it very difficult to believe the engine would have used 1 litre in one day (the capacity between maximum and minimum)
    If so, there is a serious issue that needs rectifying
    How long since last service?
    You can use pretty much any synthetic oil you want, as the car is out of warranty
    Don't go any lower than 10W40
    Regular Member david.aka.judas's Avatar
    Suffolk
    he has to - 5/30?
    or am I missing something?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Personally, I would use the grade and standard specified in the manual.
    You won't go wrong with that. As to make of oil, up to you.
    UK
    Quote Originally Posted by the-wizard View Post
    It's a 52 plate and has 79K on the clock! Sounds interesting I may try something slightly different. I managed to get Casterol 5W30 last time for a bargain, think it cost £14 for 4/5 litres.
    Yeah you are probably right - well I don't mean to say it used it up just that day. I think the pressures didn't exactly help and it was apparent after this journey as the warning light came on then.
    It's been 7K miles since the last service. So its getting ready for some fresh oil, just waiting for the snow to melt!!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    When you said the oil light came on, which do you mean the Oil Level Sensor or the oil pressure warning light?
    UK
    Quote Originally Posted by Ste View Post
    Oil level sensor, and when I checked it was below the minimum marker!
  1. oil grade
    By chris1984 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2012, 08:05
  2. possible key up grade?
    By unreal_event_horizon in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2010, 20:06
  3. What grade oil do i need
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 12:37
  4. VXR Oil Grade
    By BigP in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2009, 06:41
  5. Oil Grade 2.0T
    By 2ltrT in forum Engine & Drivetrain
    Last Post: 30th July 2007, 22:00
