Thread: spacers
    Regular Member john-d's Avatar
    Nov 2009
    washington
    Default spacers
    do any of you fine chaps know:
    if i run 20 mm rear spacers on 225 40 18s, et 43 offset will i get rubbing if i run coilover springs with adjusters removed
    Oct 2007
    Shropshire
    Normally coil over springs are a smaller diameter to give you more room....
    Hanging Heaton / Batley
    14 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Sure there's a member on here running 20mm rears and 10mm fronts on 18's... its lowered but not sure if its coilovers...
    Nov 2009
    washington
    the good thing with coilies is i could adjust accordingly, the fixed rate kits available just arent low enough
    brum
    mines dropped 100mm on supersport coilovers with adjustable carriers removed and its not even close to rubbing with 19s. Im going to go down the spacer route as thy seem to look too tucked into the arches.
    Where did you get yours from?
    Nov 2009
    washington
    Quote Originally Posted by bigben View Post
    you can get the bolt onto hub spacers on ebay
    14 Post(s)
    Mileage : 110k
    Search saab spacers too, as sometimes the 5 x 110 pcd ones are cheaper then the vauxhall ones...
    Anyone else running spacers as i'm planning 20mm rear and 8/10 front possibly in future...
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    you shouldnt get any rubbin with those setting even with the lowest coilover settin.
    im runnin coilovers with 225/35/19 tyres, with an ET35 and want to get 20mm spacers for mine and there should still be a bit of room left.
    14 Post(s)
    Mileage : 110k
    Quote Originally Posted by carl bear View Post
    You planning any for the front too?
    no, ill get rubbin on the front if i do. had to slightly pull the arch to get these to fit without rubbin round the corners (just pulled the arch out with me hands).
  1. Spacers
    Last Post: 15th April 2012, 00:37
  2. spacers
    By Jow20 in forum Styling
    Last Post: 30th January 2012, 18:51
  3. spacers ?
    By Wolflinn in forum Styling
    Last Post: 19th January 2011, 12:58
  4. will i need spacers with these?
    By ashleyaluminum in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2010, 16:30
