Results 1 to 10 of 22
Thread: inlet manifold replacement
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Question inlet manifold replacement
    hi there the garage is replacing my inlet manifold under warranty i need to know if they replace the inlet manifold will they def need to replace the swirl flap motor and if they order the manifold does that part come with it or is it a seperate order as this is a independant garage and not a vauxhall dealer
    hope you guys can help i need to know by 2moro as the manifold is off and they are fitting it 2moro thanks guys
    kings lynn, norfolk
    can any one help me please before tomorow thanks
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    When mine was replaced under warrantee, they did the lot, but at a VX garage. You could always ask them?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    YES! Defiantly get the swirl motor / solenoid.
    They 'learn' to a inlet behaviour so a used one on a new inlet will not be good.
    Middlesex
    Trim : SRI
    Mileage : 100k
    ....and its a separate part also
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    That's crap in my opinion. The movement of the flaps it's exactly the same. I changed my inlet without the motor and it works 100% as it should.
    This is the exact movement as the original inlet. What can possibly go wrong if you don't change the motor, right?
    http://www.youtube.com/watch?v=F2fnwWuyI_4
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    Quote Originally Posted by AntSSSS View Post
    yes as above you will get a new actuator, as they wont leave the old one in
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Lao View Post
    Well - each to there own..
    But take a look from the official manufacturers PDF sheet - Important Notice on page one:
    http://www.ms-motor-service.com/xima...093_en_web.pdf
    Sorry - I believe the manufacturers this time.. and if you are going to the whole expense of replacing the inlet - why wouldn't you replace this - in comparison they are not expensive, doesn't make any sense not too..
    Up to you tho - but seriously REPLACE IT.
    It is a separate part and will NOT come with the inlet, so order it up.
    Apr 2008
    Lincs
    if you replace the manifold and not the actuator, in 6 months when the actuator fails you will have to pay out for the manifold to be taken off again not cheap
    make sure they do it
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Grimo72 View Post
    EXACTLY! see previous thread with PDF from Manufacturers
  1. Replies: 0
    Last Post: 6th March 2012, 18:24
  2. 1.9 Inlet manifold replacement 'how 2'?
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2010, 02:27
  3. Inlet Manifold / Swirl Valve DIY Replacement
    By jon page in forum Engine & Drivetrain
    Last Post: 19th April 2010, 07:26
  4. Inlet Manifold replacement price advice...
    By Dan_BlackSRi in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2009, 09:05
