Results 1 to 10 of 20
Thread: Condensation on Front Lights?
    Regular Member joejdx's Avatar
    Glasgow
    confused Condensation on Front Lights?
    Hi Guys,
    I've noticed some condensation on the inside of the light casing of my new SRi Vec
    On one side it cleared up and the other side was mostly away after a day or 2 ... however it's now back a bit on one side
    Does anyone know how to get rid of this or what might be causing it?
    Thanks!
    Regular Member gotlosi's Avatar
    hampshire/uk
    do you have both bulb covers fitted?
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    this happens to the majority. try placeing some sachets of silca gel into the rear of the lamp
    Jan 2008
    Dundee
    Quote Originally Posted by joejdx View Post
    Hi Guys,
    Thanks!
    Quote Originally Posted by gotlosi View Post
    Yeah also check that because i left one patially off and it caused the whole lamp to steam up. I had to take the lamp out and drain off the water
    hampshire/uk
    Quote Originally Posted by Keithy View Post
    hmm think youve got the solution if you have the covers on. im also going to give this ago.
    Regular Member Exotica's Avatar
    Jan 2010
    Surely you would get this no matter what you do in these temps. Hot area meets cold area etc.
    Leicester
    Don't bother with the silca sachets, there is a proper VX fix for this problem.
    Vauxhall do a snorkel kit for the foglights which solves this problem. Mine fogged up big time, but had the snorket kits fitted and it's not been an issue since.
    Jan 2008
    Dundee
    Quote Originally Posted by Maverick View Post
    Is this the same for the headlights?
    Glasgow
    I've checked the bulb covers and taken them off and back on again - there are 2 plastic one's and 1 rubber one on each side ... have I missed any?
    It is still happening and even when it clears up it comes back again!!
    Very annoying ... any other ideas?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    You probably have a small amount of water in the bottom of the head light shell , only real cure is to remove the headlight drain it and then dry it out with a hairdryer. i did this with my offside one recently and drained about a quarter of a pint from it.
    now its fine.
    and still loving it
  1. condensation in lights
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2013, 21:39
  2. Water, condensation or misted Fog Lights (Foglight)
    By omega2498 in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 09:46
  3. VXR front fog lights
    By lee gsi in forum Insignia car chat
    Last Post: 10th March 2011, 19:06
  4. Estate rear lights condensation
    By fastbatard in forum Bodywork & Interior
    Last Post: 25th February 2011, 23:38
  5. Condensation on nearside front foglamp on signum
    By mikebeasley in forum Bodywork & Interior
    Last Post: 25th May 2009, 19:54
vectra c facelift lights condensation
