how do you get to the bottom bolt for removal??
cant see any easy solution dont want to be taking the bumper off if anyone has a tip id be very grateful
bumper has to come off mate. its an easy job to take the bumper off
sorry but its bumper off m8
was hoping that woulnt be the case but hey ho out in the snow to get it off
cheers guys
while im on top topic of removing things how do i get the side repeaters off one of mine is cracked and id like to replace it
You can use a credit card or something similar to be easier for you to pull it from the rear bit.
you do not need to take bumper off to change dipped beam headlight bulbs, its a 5min job tops for both sides, well on a facelift anyway
pre-facelift?? undo the torx bolts in the wheel arch, pull outwards off the poppers and pull it slightly down should be able to see and get at the bottom bolts with a socket....I did anyway
