Thread: Faulty lpg
    Jan 2010
    LEIGH
    Unhappy Faulty lpg
    When starting up the engine, nine times out of ten it will not switch to gas or the engine will completely cut out.
    Recently had gas side serviced but still continuing as before if not a little worse.
    Also the temperature inside the car seems to take a lifetime to get warm and on the temp gauge too!
    Plz help!
    May 2007
    fleetwood
    hi, the engine coolant has to be warm in order for the gas to come on, so i suggest you check coolant levels and for any air locks
    andy
    Jan 2010
    LEIGH
    Default Faulty LPG
    thanks for the advice,will take a look at that!!!
    will let you know how i go on.
    cardiff
    My lpg switches over to gas within 30 seconds or so even in the coldest weather. I dont think the engine has to be that warm for it to switch over.
  1. Faulty MAF (I think)
    By gerryo in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 14:08
  2. Faulty maf
    By Mattle40 in forum Engine & Drivetrain
    Last Post: 16th January 2012, 23:21
  3. faulty speedo
    By trickyjacks.4 in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2011, 15:37
  4. Does Faulty EGR cause less MPG?
    By markluk in forum Engine & Drivetrain
    Last Post: 24th February 2009, 21:32
  5. faulty tps
    By Morephun in forum Engine & Drivetrain
    Last Post: 13th February 2009, 21:19
