Results 1 to 10 of 13
Thread: Door Handles / How Do I Remove - Refit
    Ex-Staff Full Member Mark The Cabby's Avatar
    Feb 2006
    In a house
    Vehicle : Ford Mustang
    Trim : GT
    Engine : 5.0 V8
    Year : 2016
    Default Door Handles / How Do I Remove - Refit
    Let it says in the title,
    Any ideas folks???
    It's Mustang time...
    [Ex]Admin Duncan's Avatar
    Sheesh, you're soooo impatient!!
    I'll look at TIS on Monday when I'm back home - unless somebody else beats me to it.
    Feb 2006
    In a house
    Trim : GT
    Engine : 5.0 V8
    Year : 2016
    Yes i am, and that's what i'm hoping for...
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    Why do you need to remove door handle's Mark?
    Feb 2006
    In a house
    Trim : GT
    Engine : 5.0 V8
    Year : 2016
    Quote Originally Posted by Robbieben
    To put new ones on Robbie...
    Regular Member signumT's Avatar
    grimsby
    Might help until duncan gets u it or tells me how to make it into a pdf as no piccies came out
    Outside Handle – Front Door, Remove and Install
    [IMG]file:///C:/Program%20Files/cosids/DATA/TMP/REMOVE.gif[/IMG] Remove
    1. Open front door
    2. Remove cover cap (1) out of front door (3)
    • Lever cover cap (1) out of front door using plastic wedge (2)
    • Remove cover cap (1)
    3. Remove front door outside handle
    • Pull movable handle part (2) outwards and hold
    • Turn 1x bolt (1) to the left to the stop using torx screwdriver
    Note: Movable handle part (2) must now be secured in pulled position
    4. Remove fixed rear handle part (1)
    5. Pull movable handle part (1) to the rear (arrows) and remove
    [IMG]file:///C:/Program%20Files/cosids/DATA/TMP/INSTALL.gif[/IMG] Install
    6. Release front door outside handle
    • Guide movable handle part into door panel and latch into door handle cage
    • Insert fixed rear handle part
    • Turn 1x bolt to the right to the stop using torx screwdriver
    Note: Hold movable handle part taut while screwing and lightly counterhold fixed handle part.
    7. Insert cover cap into front door
    • Insert cover cap
    8. Close front door.
    Feb 2006
    In a house
    Trim : GT
    Engine : 5.0 V8
    Year : 2016
    Come on then Duncan
    P.s. Pic's too...
    PMSL - I just saw you online and was on my other PC doing the PDF! Sheesh!
    Feb 2006
    In a house
    Trim : GT
    Engine : 5.0 V8
    Year : 2016
    And the pic's of stowmarket???
    come on mate i've been a good boy, Honest...
    Quote Originally Posted by Mark The Cabby
    I'm getting there, I'm getting there! Got stuck straight into work when I got back - now I'm in 'play' mode!
  1. How to refit drivers door card...
    By peterc2609 in forum Bodywork & Interior
    Last Post: 21st June 2015, 22:58
