Thread: Might have a problem
    Oct 2009
    Machynlleth
    Unhappy Might have a problem
    Yesterday driving back from a mate's, had a problem selecting gears, wouldn't go into reverse at first, finally managed to get it all was well. Then about 9miles down the road, i couldn't get 4th. Managed to get that in the end with a bit of messing.
    Any ideas as to what it could be?
    Not loosing any fluid, had the master cylinder changed 2 months ago, and clutch/dmf is fine.
    Im having loads of problems with my car atm.
    Nov 2009
    Norfolk
    I had a similar problem with the others halfs astra.
    Tried adjusting the linkage loads of times (tells you how in the haynes manual)
    Never really seemed to work.
    In the end found there is a weird shaped pin that goes through the linkage (in the engine bay)
    This had strted to fall apart.
    Got a new one from Vauxhall for about a quid! never had any any more problems!
    To find the part they need to keep zooming in on the EPC to find it!
    Regular Member JockMcMann's Avatar
    scotland
    my brother had a similar problem but it was his gear box mount that had came loose
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Most likely the linkages, I lost 1st and 2nd gear in the Corsa I had three years ago.
    Oct 2009
    Machynlleth
    Thanks guys. Think i will just have to take it a garage and have them look at it.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
