Thread: Help please
    Oct 2009
    lincoln
    Default Help please
    hi just changed my front fog light bulb, but warning light on dash is still on and bulb isn't lighting up?
    Northampton, UK
    Try moving it to the other side to see if you've got a duff bulb mate
    Oct 2009
    lincoln
    tried it mate works fine in other side
    Northampton, UK
    Is there a single fuse for both sides or one for each?
    Oct 2009
    lincoln
    have not got a clue mate. what number is the fog light bulb fuse?
    Northampton, UK
    I think it might be posted on the inside of the fuse box lid?
    Edit - There's only one fuse, F12, so if one lights working its not that.
    Oct 2009
    lincoln
    All sorted now....
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    what was the solution?
    Oct 2009
    lincoln
    i dont know really i tried turning it on with the wire hanging no joy then put it in the light housing and it worked????
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    fogs you need to connect the wire properly, if its a little out it wont work
