Results 1 to 10 of 14
Thread: Center Display Problem
    Jan 2006
    milton keynes
    Default Center Display Problem
    Hi for some reason i started the car this morning and my center display dosent light up. can anyone help? ive checked the fuses and they look ok. if i look real close i can see that it still works but it nolonger glows orange making it impossible to see.
    please help....
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    maybe a bulb that illumiates it gone?
    Jan 2006
    milton keynes
    oh. do you think it will be covered under warrenty? as my rear washer disconnected its self a few weeks back (causing me to have a very wet headlining) and the dealer said "theres no new parts needed just an hours labour so that will be £98!!!!!!) and if its easy enough could i change the bulb myself?
    Cheeky W***ers, yep should be covered under warranty, do you have another garage near you though ? Sound like a bunch of Cowboys ....
    Jan 2006
    milton keynes
    im in milton keynes and the next nearest one is in northampton (about 25miles) just a bit of a pain in the butt as i only bought the car in september and its already been in to vx 12times for faults. i love the car but im gutted about the niggles.
    I had the same start to my Vec mate, was in the garage 2-3 times a month for the first few months, nearly got shot of it, but then they sorted it and I have had no problems in the last 18 months so worth hangin in there ....
    Jan 2006
    milton keynes
    cheers fella. nice to know im not the only one out there with car issues.
    [Ex]Admin Duncan's Avatar
    Maybe a daft question, but have you gone into the computer menu to double check that the contrast setting hasn't, for some daft reason, dropped right down to minimum?
    It's not bulbs behind the display that iluminate it, it's liitle LED's wired onto a circuit board so basically not replaceable by you - unless your feeling very brave.
    It's definitely a dealer job - and it should be fully covered under the warranty for parts and labour.
    Your dealer was 'in the right' to charge you for the washer jet thing - it's not really a warranty thing - but how ferking much is their hourly rate!!!! Not to mention the fact that it shouldn't have taken an hour do to! To drop down the rear headlining and reconnect the washer pipe is a half-hour job (max). I'd be having words!
    Melbourne, Australia
    Can you see any illumination at all? Even if the contrast is badly adjusted, you should still be able to see some glow from the display area.
    It's probably not the LEDs that have failed - LEDs generally don't fail! Perhaps the wiring that conveys the display brightness is damaged somehow. Does it make any difference if the headlamps are switched on?
    Perhaps our warranty expectations are different, but I would expect that the car shouldn't fall apart; I dare say anything that involves pulling off the headlining is not exactly supposed to be regular maintenance...
    Jan 2006
    milton keynes
    all my dash board lights still light up its just the central display thats completely black. if i catch it in the sun i can see that it still works but unless the sun is directly shining on it i cant see anything.
    ive adjusted the dash lights so there as bright as they can go and still nothing. is there anyother way of adjusting the contrast on the display? is only a mono jobbie just showing time, temp and radio station.
  1. Display screen problem
    By ScotsDragon in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2010, 17:40
  2. Display & cd player problem - help please
    By alexander08 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2010, 17:35
  3. CD30 Display Problem
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 23:17
  4. display on pc problem???
    By kgsric in forum General Chat
    Last Post: 3rd September 2007, 21:12
  5. information display problem(me thinks)
    By lapat in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2005, 00:54
