Thread: Cold starting problems!
    cardiff
    Default Cold starting problems!
    2nd post on here about this, basically a 2005 1800 duel fuel is a right b**ger to start when cold, its taking between 12-15 seconds of cranking before it fires up. ive changed the coil pack and plugs (using the recommended lpg plugs at over £5 each.....) and made no difference. when started it runs fine and i dont think the lpg system is effecting it as it always starts on petrol.
    does it have some form of cold start device fitted to these engines? and if so anyone had issues with them?
    its starting to spoil my previous god thoughts about the car which is a shame as everything else is great with it!
    would apprciate any thoughts/ideas
    Ps- no faults showing, car has done 50K with full man dealer history serviced last about 1500 miles ago, the plugs that came out looked fine too.
    Thanks!
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Think in this weather everyone is having problem's sorry cant comment on your's but i'm sure some one will be able to offer some advise
    Irmscher Insignia CDTI 130
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It 'could' be sensor related. Yes the ECU has a 'cold start' function but it will only adapt the fuel injection rate and shape IF it knows about it. Does your temp gauge work OK?
    Or, it could be perfectly normal witha dual fuel system (as it will pgysically differ slightly from pure petrol system)
    cardiff
    Temp gauge is a problem which i thought was stat related, but i wasnt sure if that would affect cold starting? the gauge shows zero most of the time unless round town when it creeps up a little, i was thinking this was a stat problem and have a new one to fit when it warms up a little.i think i may need to change the stat asap to try to rule this out.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    How good's your battery???...
    cardiff
    luckily battery is good,turns quickly and so far is holding out well! hasnt gone flat on me yet.
  1. 2006 1.9cdti Cold Starting Problems
    By rjcotterill in forum Engine & Drivetrain
    Last Post: 7th June 2011, 16:15
  2. My Vectra C 2003 DTI cold starting problems solved hopefully
    By jameso in forum Vectra C / Signum Troubleshooting
    Last Post: 29th January 2011, 15:18
  3. Problems starting 2.2 petrol in cold
    By phil_l875 in forum Engine & Drivetrain
    Last Post: 20th December 2010, 13:45
  4. Bad Starting From Cold
    By PAULMAC77 in forum Engine & Drivetrain
    Last Post: 7th October 2008, 11:48
  5. Starting cold Problems
    By vectraspain in forum Engine & Drivetrain
    Last Post: 13th April 2007, 18:23
