Results 1 to 10 of 15
Thread: how to remove glowplugs
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default how to remove glowplugs
    gonna change my glowplugs tomorrow is the how2 for the 1.9 the same way as the 2.0dti?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I would remove when engine is hot and soak them with wd40 or something before you do it as you dont want to snap one
    Irmscher Insignia CDTI 130
    Oct 2009
    Sandwell
    Quote Originally Posted by bigmac View Post
    so go for a run in the car and then soak them with wd40? (with leads off )
    are they in the same place as the 1.9 how 2?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    They are at the back of engine think they are clipped on so you have to be careful unclipping them from plug
    Oct 2009
    Sandwell
    cheers i would of thought going for a run to heat them up would make them tighter due to the heat so they would be hard to get out?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Not sure buddy thought i read a thread saying its best to take them out when engine's hot i need to do mine but i can get mine done at Vx for about £100 and if they snap one then they will have to fix
    Oct 2009
    Sandwell
    just had ago at trying to remove the plugs i couldnt even get the leads off them, how do you get them off??
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Think you squeeze the bottom of the clip in together and pull off gently
    Oct 2009
    Sandwell
    just fitted all 4 who ever said use a screwdriver to get them off ****** hell you will snap somat, i found out if you just pinch the top clips in and pull up they come off, thnaks BIGMAC
    since disconnetimng battery ive noticed the deadlock wont work does it have to be programmed??
    its sorted now,,,,
    out and about
    soak them with wd40
    Why use WD40? Why not use a penetrating oil such as Plus Gas?
    WD40 is a Water Dispersant - a very good one - but it is NOT a penetrating oil
    ultrablue
  1. Where are the Glowplugs on 1.9 120
    By Marky in forum Engine & Drivetrain
    Last Post: 4th January 2011, 16:21
  2. Testing glowplugs?
    By Dazzy2006 in forum Engine & Drivetrain
    Last Post: 17th December 2010, 01:09
  3. Dti Glowplugs
    Last Post: 2nd December 2010, 20:20
  4. Maybe more then Glowplugs
    By danny1992 in forum Engine & Drivetrain
    Last Post: 24th November 2010, 15:37
  5. glowplugs
    Last Post: 23rd December 2009, 10:36
