Thread: 12v Socket fuse location & heated mirror
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default 12v Socket fuse location & heated mirror
    Having lost (well, its in a cupboard somewhere!) the manual for the vectra, finding the fuse for the 2 12v ciggy lighters is not easy and do not want to randomly pull them all out!
    Can someone have a quick look in their manwell and let me know what fuse it is? It is only the 2 sockets not working, stereo, lights and everything else is fine.
    Secondly, I assume the wing mirrors are both heated from the same fuse? Drivers heats up ok but the passenger side does not. Took the glass out and seems to be still connected but does not warm up. Kinda hoping it is a fuse but doubt it, anyway, is it hard to change the internals or is it better to just change the whole mirror?
    TIA.
    Apr 2009
    Skelmersdale
    [I] have had my manual out as the info display stopped working , thought was the fuse but just the cold weather as burst into life when car warnmed up but anyway the ciggy lighter fuse is no 22... 30 Amp its the bottom one on the 3rd row.. Hope this helps . its the fuse box on side of dash by passanger dor.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If you need a manualdownload it here:
    http://www.vauxhall.co.uk/vaux/pages...uals/index.jsp
    west yorkshire
    the rear cig lighter fuse is also in the back fuse box too. f17 15 amp.
    Dunstable
    Front cigar lighter - Passenger fuse box - F22 / 30A
    Rear cigar lighter - Rear Fuse box - F17 / 15A
    The only ones I can see that are relevent for the mirrors are F15 / 30A which is the RH front door control unit, and F8 / 30A which is the LH front door control unit, again both located in the passenger side fuse box. According to the wiring diagram, the electric mirrors use these fuses, so worth checking them I guess, other than that, could be a faulty heater element in the glass? Worth checking the 2 terminals that plug into the mirror to see if you are getting power going to it with a multimeter and your heated rear window switch turned on to send power to the mirror heater elements
    Tain - Easter Ross
    Quote Originally Posted by calbert07 View Post
    [i] have had my manual out as the info display stopped working , thought was the fuse but just the cold weather as burst into life when car warnmed up but anyway the ciggy lighter fuse is no 22... 30 Amp its the bottom one on the 3rd row.. Hope this helps . its the fuse box on side of dash by passanger dor.
    Superb, will go and investigate!
    Quote Originally Posted by paulhb View Post
    Tremendous! I must go find my one too.
    Quote Originally Posted by tony stoney View Post
    So the 2 sockets are seperate fuses?!
    Quote Originally Posted by Ademusic View Post
    Had the glass out and put it back in and the mirror was OK, got home from work today and its now cracked!
    Anyone seen my multi-meter?
    Dunstable
    Quote Originally Posted by RobW View Post
    Tain - Easter Ross
    12v sockets sorted, didn't have a spare so just took one out of the rear electric windows, why the fuse would be there is amazing!!?
    Just the mirror to sort now, the passenger door control fuse didn't work, it cut power to the window and boot switch but did not help the mirror. Must find my multi-meter.
    Dunstable
    Glad you got the socket sorted! I'm sure it's just a dodgy mirror glass, but without testing the contacts or putting a replacement glass in we won't know....don't know where your multimeter is though..
  1. N/s low beam fuse location
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2012, 15:23
  2. Heated mirror fuse
    By Daywalker in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2010, 20:26
  3. fuse location
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2009, 16:57
  4. TC fuse location?
    By dh.dti in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 11:04
  5. Connection on rear fuse box for a 12V socket
    By Duncan in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2007, 15:03
12 v charger fuse vauxhall vectra
opel vectra c 12v back fuse
vectra c heated passagers mirror not working
vectra 12v socket fuse
Vauxhall insignia accessory socket fuse
heated back window not working on vauxhall vectra 06
trax mirrors fuse
12v socket fuse on vectra c
12 v power supply fuse vectra
fuse location for vectra c 12v socket
vectra c 12v sockets not working
vectra c 12v fuse
where is the fuse for electric mirrors on vectra
man tgx 12 v socket not working
cigarette lighter fuse vauxhall vectra c
12v socket fuse vauxhall vectra sri
vectra c 12v socket fuse
where is the fuse for the rear accessory socket on a c vectra
insignia rear cigarette loghter not working
cigarette lighter fuse location opel vectra c 2002
fuse for zafira 12v 30A
where is fuse for vectra electric mirrors
vectra c voltage heated mirror
fuse for 12v cigarette charger in a vectra
where is fuse vectra b heated mirrors
