Thread: Front Courtesy Light Change
    Regular Member maurauth's Avatar
    Southampton (Locks Heath)
    Default Front Courtesy Light Change
    Anyone know how take the plastic cover off the front courtesy and map reading lights without scratching the plastic around it with a screwdriver?
    When I did it in my Vectra it ended up with a gouge mark on each side from the screwdriver, as it already had small ones from the previous owner.
    Was wondering if there's a way of doing it without damaging the plastic as my Signum's unit doesn't have any scratches?
    milton keynes
    Quote Originally Posted by maurauth View Post
    Are you taking about the opaque part , so you can replace the bulbs ? If so press the map reading lights on and then use your fingers to apply a small bit of pressure and it will pop out. No tools need for this.
    Hanging Heaton / Batley
    16 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    pull the interior alarm sensor off, come away quite easy if push towards windscreen.. then push the bulb cover clips from behind... lot easier
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Very easy just remove the alarm sensors jobs jobbed
    Cheers both
  1. Courtesy light
    By mikey362 in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2012, 01:52
  2. Front light bulb change
    By Vectrarmand in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2011, 15:54
  3. front courtesy light
    By Keithy in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2010, 19:21
  4. Front courtesy light, fuse number
    By sirnapper in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2009, 15:41
  5. Courtesy light
    By peter142 in forum Bodywork & Interior
    Last Post: 11th June 2007, 23:07
how to remove front courtesy light on vectra c 2008 2.2
