Thread: Headlight Fuse
    Regular Member TopRod's Avatar
    Liverpool, UK
    Question Headlight Fuse
    Does anyone know if the fuse for the headlamps on the 07 Vec, SRi is a 20 amp? Just got a HID kit from HIDs Direct and when I read the manual it says the headlamp fuse needs to be at least 20 amp or it will burn out.
    I'm sure it is, even so, the HID kit runs at a lower wattage anyway doesn't it? So it can't burn out can it?
    On a second note I thought the kit was very well made well impressed Going to put it in some time next week. Will show the before and after.
    Its probably a 30amp in there using ohms law to do a quick calculation. if in doubt its in the manual
    Liverpool, UK
    In the manual its showing up as a 10A fuse so I'm assuming that I should replace this with a 20A fuse. In the manual for the HID kit it says not only can it blow but it can cause problems such as strobing and shut downs so maybe thats why people are experiencing problems with their HID kits. I don't know tho
    Liverpool, UK
    I connected the HID kit up today to see if it worked fine, and it does. I can't wait to install them properly and see what they are like at night.
    One thing I did notice tho is that the fitment for the bulb (the base which secures the bulb in place) was ever so slightly smaller than the standerd one. I went in easier than a standerd bulb but I also noticed that it was easier to move about (and take out) in the socket once in place. I'm going to test them while I'm driving tomorrow to see if they bounce about or even come out of the sockets. If they do, does anyone have any tips on securing them properly? If not I'll have to get onto HIDs Direct I think.
    Has anyone else had this problem at all?
  1. Headlight adjustment fuse ?
    Last Post: 9th June 2010, 18:07
  2. headlight fuse
    By penfold1981 in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2009, 16:29
  3. Headlight washer system fuse keeps blowing
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 19:58
  4. headlight fuse ?????
    By deano1 in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2008, 18:42
  5. Headlight bulb fuse wattage?
    Last Post: 30th July 2007, 16:48
vectra c headlight fuse
vectra c headlamp fuse
headlight fuses vectrac
vectra 2005 headlight inop
os headlight fuse 2007 vectra
vectra c headlight fuse number
headlight fuse in insignia
opel vectra c 2006 headlights fuse
vauxhall insignia headlight fuse
vectra c head lamp bulb fuse no
headlight fuse location on 04 vectra
vectra c headlight motor fuse www.vectra-c.com
were is the headlight fuse on a vectra c
2005 vauxhall vectra sri headlight fuse uk
